panasonic hdmi cec
hi my panasonic definitely has this ability because i can use hdmi link in ps4 system but i don’t know why it doesn’t work out in rasplex should i configure any settings?
Definitely works with Panasonic TVs, I have one, have you checked the settings, both on TV and Rasplex.
Regards
you are right i dont know why earlier it didn’t work i decided to format micro sd card and install it again this time worked btw panasonic is the best tv i have sony and other but regardless than my panasonic is old(2008) its support for everything is more than any other tv
