My Plex server is running on Windows.
Server Version#: 1.30.1.6497 (x64)
I’ve read https://support.plex.tv/articles/201154537-move-media-content-to-a-new-location/ which I’ve successfully used when replacing a drive, or moving everything at one time to a new location. And seen lots of questions about moving an entire library from one drive/folder to another, but none talk about moving a partial library.
Long story short, because 8TB drives were available I created a pool of them (“Drive F”) and put my movies there Since then, I added a pool of 14TB’s (“Drive G”). Because it was a lot less data to move, I moved my TV shows to “Drive G”. YUP I didn’t think about the future.
Well NOW “Drive F” is filling up, and its not worth buying new 8TB’s, and the 8TB pool I have is still good… So I want to move my Movies to “Drive G” (the pool of 14TB drives), and my move my TV Shows to “Drive F” (the pool of 8TBs).
I’ve already stopped plex and moved the TV shows. It took way longer than I expected. Because of how much space the movies take up… I know its going to take a while and I don’t want to move all of them at one time.
Is there any issue following the above instructions kind of. Like basically stop plex, move part to the new folder, then rather than remove the old folder, start Plex, add the new folder, let it scan… and keep plex running, then in a few days from now, stop Plex and repeat? And once everything is finally moved, remove the old folder path.
Or will it cause an issue? Do I NEED to move the entire movie folder at one go?
My guess it it will probably be ok moving part today, part “next week”, but just want to make sure. I’m also guessing it will just rescan my folders, pickup the files in the new location as if it was new media, and remove the entry from the old as if I deleted the old file?
