When setting up the live tv you can either input a url or a path to the xml epg guide. My question is where can I place my xml file so it can be read from the local filesystem?
I already reviewed this guide: https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
I also already tried placing it here and then using that path, which did not work:
/Volume1/Plex/Library/Application Support/Plex Media Server/
