Pause and FF/RW not working after update to latest iOS
Hello
I couldn't find any other mention of my problem. But it is as above. After updating ATV software I can no longer pause or fast forward/rewind when watching videos.
Is this a cause of new software? Will there be a fix? Has this already been asked?
It is not a major issue as can just exit the video for now.
Thank you.
http://forums.plexapp.com/index.php/topic/81253-progress-seek-bar-issue-after-ios6-update/
:-D
Hah, I actually did look at that originally, just not the part where he mentions not being able to ff/rw.
Disable subtitle under atv settings if you have Dolby digital enabled. Or the other way around.this is a temporary fix and hopefully the great plexconnect team finds a fix, most likely they will
I changed the settings from Dolby Digital ON to AUTO, subtitles ON (as before), and everything was back to normal again
