Progress/ Seek Bar issue after iOS6 update
ATV MODEL: ATV3 6.0 (6646.65)
DNS: 192.168.1.5
O/S: WINDOWS 7 DESKTOP
IP: 192.168.1.5
PMS VER: 0.9.8.6.175
PLEXCONNECT VER: GITHUB 09/20/2013 6:07 PM
SETTINGS CFG:
  PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = Normal
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
enable_webserver_ssl = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
MEDIA INFO:
Video Resolution 1080p
Duration 1:46:41
Bitrate 10026 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
FILE
Accessible Yes
Exists Yes
Duration 1:46:41
File D:\Videos\Movies\This Is The End.mkv
Size 7.47 GB
Container MKV
VIDEO
Codec H264
Bitrate 10026 kbps
Language English
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Duration 1:46:41
Frame Rate 23.976 fps
Frame Rate Mode cfr
Has Scaling Matrix 0
Height 800
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
AUDIO
Codec DCA
Channels 5.1
Bitrate 1536 kbps
Language English
Bit Depth 16
Bitrate Mode VBR
Duration 1:46:41
Profile ma
Sampling Rate 48000 Hz
SUBTITLES
Language English
Format SRT
ISSUE:
Progress/ Seek Bar unable to fast forward/rewind or pause when close captioning is enabled on play screen. To save the trouble of explaining, I;ll provide a link to the video showing the issue.
video link: http://www.youtube.com/watch?v=x4Xsl2jiN4Q
still too large. don't know whats wrong
PLEXCONNECT LOG: unable to attach file, apparently its too large
1. Exit out of PlexConnect
2. Edit Settings.cfg and change loglevel = Normal to loglevel = High
3. Delete your PlexConnect.log file
4. Run PlexConnect again.
5. Recreate the problem on the ATV.
6. Exit out of PlexConnect
7. Post your new PlexConnect.log file to www.pastebin.com and post the link here.
Thanks.
at 1:25, how are you accessing that menu that's on screen?
iamjustme: For the posted log... is it possible to get the lines a couple of second before that? I would like to have a look at both the XMLs (PMS and aTV) of the PrePlayScreen.
Baa, I uploaded the entire log in dropbox
just press and hold select button. make sure you have ios6
Nice read... :-P
Nice read... :-P
I can`t imagine someone reading those logs in their entirety. Its too much text man!
I haven't done the update, and now that it's been pulled (plus the issued faced by other Plex members) I'm glad I didn't. But what you are telling me is that option didn't existing until this recent update to iOS 6?
The option has always been there, but as far as I know it only works on non transcoded media, ie stuff that would normally play on the atv via iTunes and homesharing, mp4, m4v and some direct played mkv's.
I see. hmmm. I press and hold Select and just get a paused media. pout. Thanks for the reply roidy!
As I said it only works on media that would natively play on the atv. Like purchased iTunes content or stuff you've encoded/remuxed to be iTunes compatible.
Hey guys, find a fix for this annoying bug?
