Photo slide shows
Hi there
... is it just me or are some slide show styles not playing all photos within the folder?
E.g. "Origami" is repeating after like ~ 50 photos
cheers!
There are two more issues with the Photo slide show:
a) During a slide show, some (random) photos are not shown, instead, there is just a black screen, usually followed by several oder black screens until a photo is displayed. I know, that the slide show went on because when you exit the slide show mode, it jumps to the last whown image - which may be one not being displayed. Using Baa's mod from https://forums.plex.tv/topic/84837-photo-rotation-exif/#entry491388 prevents photos from not being shown, but with
{{IMAGEURL(Media/Part/key::1280:720)}}
all photos (regardless slide show or not) are displayed very pixelated - so, the mod does not work anymore (rotation seems to work without the mod now).
b ) It happend to me, that in the middle of a slide show, it jumped back several photos and photos already showed are showd a 2nd time (of course random mode is off).
Any one is encountering similar issues?
Cheers!
I already posted a similar problem some time ago:
https://forums.plex.tv/topic/82823-black-screen-when-using-slideshow-for-photos/#entry476931
When I'm using resized or small photos, it is working without showing black screens.
... the problems mentioned above still exists - now, even photo rotation upon exif information is broken again...
are these issues an issue? :)
Well, if those issues hurt you, I guess they ARE an issue.
We haven't had much time to look into, though. But be assured, we keep all issues on a list.
... Somewhere.
... Anybody seen that list?
... Argh, where is that list now?
... Helloooo?
:-D
As for the "pixelation" when transcoding your pictures - try increasing the transcoders output size. Like
{{IMAGEURL(Media/Part/key::1920:1080)}}
I really wonder, why aTV might have picked up the EXIF rotational information at one point, and disregards it again? Are you sure you checked the same pics/same process of displaying them?
Hi Baa
I've already tried this with no effect. It's not a 720 vs. 1080 pixelation, it's more like a full screen thumb-image...
So adding the line above does not do the trick anymore...
regards!
The built in Apple TV slideshows repeat after 50 images or so too. It’s pretty crappy for photos. If I want to run a slideshow with lots of pics I airplay from my Mac running iphoto.
the issues from above are fixed with commit e076e37cb30ac9f72d7a52a8c1cc7da6fa4f6315 thx baa!
I also tested it with the above posted commit, but the problem with random black screens during slide shows still exists. Any ideas on that? Thanks.
