I'm seeing the same issue. The Web client, when displaying the Album view filtered by Genre, will use the genre list drawn from the embedded ID3 Genre tags. This is the correct behaviour.
However, both PHT and the Windows 8.1 app, even when set to display Albums filtered by Genre, will use what appears to be a list of genres drawn from the Artist metadata, instead of my embedded genre tags. This is not the correct behaviour.
In my opinion, this is clearly a bug, and an annoying one. Please can it be addressed.
The Web client, showing the correct Album genre list, drawn from my embedded ID3 tags:
We are investigating this, it looks like the artist genre list is displayed instead of the album genre list.
Thanks for this. And what should the behaviour be if we select "none" (don't use genres from Gracenote) in the Music library Advanced settings? Does that mean that we should not see any genres associated with artists, other than those we add manually to each artist?
@gcoupe said:
Thanks for this. And what should the behaviour be if we select “none” (don’t use genres from Gracenote) in the Music library Advanced settings? Does that mean that we should not see any genres associated with artists, other than those we add manually to each artist?
the next version of PMS will contain a fix for the ‘None’ genres issue
