Picture artifacts playing 10bit x265 files on Roku 2XS
I also originally posted this in the Roku player forum but the responses were mostly bashing the 2XS.
I’m having problems playing x265 files on my 2XS. They will play fine for awhile, then will totally distort making them unwatchable. If I restart all is well until again it acts up.
Is this a known issue? It just started for me over the last few days. I’ve tried changing my profile level but its having no effect. They files play just perfect on other devices so it seems to be a Roku-only problem.
Heres the media info of one of the files if it helps any.
General
Unique ID : 182609859702717752953972118687571574279 (0x89616133A34C83DBBD7ED692B27CFE07)
Complete name : /Volumes/MyBook4TB/TV MyBook/Lost/S01E21 The Greater Good.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 846 MiB
Duration : 43mn 22s
Overall bit rate : 2 726 Kbps
Movie name : S01E21 The Greater Good
Encoded date : UTC 2016-01-27 11:35:43
Writing application : mkvmerge v8.7.0 (‘All of the above’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Cover : Yes
Attachments : Cover.jpg
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 43mn 22s
Bit rate : 2 499 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.050
Stream size : 775 MiB (92%)
Writing library : x265 1.7+497-975352b2c022:[Windows][GCC 5.2.0][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=15 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=2 / limit-refs=0 / weightp / no-weightb / aq-mode=3 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=2501 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 43mn 22s
Bit rate : 221 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Frame rate : 23.438 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : 31ms
Stream size : 68.5 MiB (8%)
Language : English
Default : Yes
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Duration : 42mn 26s
Bit rate : 4 434 bps
Count of elements : 501
Stream size : 1.35 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 42mn 34s
Bit rate : 47 bps
Count of elements : 377
Stream size : 14.9 KiB (0%)
Language : Romanian
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:10:00.850 : en:00:10:00.850
00:17:24.377 : en:00:17:24.377
00:26:48.440 : en:00:26:48.440
00:34:03.833 : en:00:34:03.833
00:39:17.730 : en:00:39:17.730
00:42:43.644 : en:00:42:43.644
