Server Version#: 1.26.0.5715 (macOS)
Player Version#: 9.1.0.32210
Some x265 files in mp4 containers that used to play fine now play at what seems to be 2fps but the audio plays fine, is like the frames are just being skipped. Files play fine on the iOS client, the macOS client and the web client.
Most of my files are ripped with the same settings and I have some with identical size, bit rate, codec, audio channels, etc where one file plays fine and the other doesn’t.
This issue started a few versions of Plex ago but I haven’t had time to look into it until now. I can reproduce the issue on two different Hisense TVs running the same firmware (Android 9). I found two movies from 2016 that I have watched before with no issues, now one of them fails to play.
I have already tried moving the files to a different drive and re adding them to Plex and restarted both the server and the TV many times in the months since I first saw this problem. I tried turning ON the “Change Resolution” and “Change framerate” settings on the Android TV client, both together and one at a time and didn’t make a difference. For now the only way to watch these files on the TV properly is to cast them from my phone or choosing a different quality on the TV to force a transcode.
Here is a mediaInfo dump from a file that plays fine:
General
Complete name : [edited]
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 1.82 GiB
Duration : 1 h 57 min
Overall bit rate : 2 229 kb/s
Movie name : [edited]
Encoded date : UTC 2020-05-16 14:44:51
Tagged date : UTC 2020-05-16 14:44:51
Writing application : Lavf58.20.100
Comment : [edited]
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 2 000 kb/s
Width : 1 920 pixels
Height : 804 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.054
Stream size : 1.64 GiB (90%)
Writing library : x265 3.3+4-rarbg-30eb4de83092:[Linux][GCC 8.3.1][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x804 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=2000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration_LastFrame : -1 ms
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 188 MiB (10%)
Language : English
Default : Yes
Alternate group : 1
And here is one that presents the issue, virtually identical:
General
Format : MPEG-4
File size : 1.67 GiB
Duration : 1 h 47 min
Overall bit rate : 2 231 kb/s
Encoded date : UTC 2020-04-18 19:48:29
Tagged date : UTC 2020-04-18 19:48:29
Comment : [edited]
Video
Format : HEVC
Codec ID : hev1
Bit rate : 2 001 kb/s
Height : 804 pixels
Color space : YUV
Bit depth : 10 bits
Stream size : 1.50 GiB (90%)
Audio
Format : AAC LC
Bit rate : 224 kb/s
Stream size : 172 MiB (10%)
Language : English
Default : Yes
Alternate group : 1
