PIP not working on IPhone
Server Version#:
The PIP is not working on my iPhone (only for the Plex app). I have uninstalled the Plex app and reinstalled it, did not fix the issue.
I do have it turned on in the Plex app setting.
PIP is working on my iPad.
Is anyone else having this issue? If so have you been able to fix it.
Auto PIP only works when the “old player” is used (Plex settings → advanced). Otherwise you can manually enable PIP using the button near the top right during playback.
Using the Old Player did fix the auto PIP but still seems like a bug to me.
We use MPV rather than Apple’s AVplayer is why. Some info here iOS App Update = Picture in Picture Dead - #9 by DaveBinM
Thank you for the info. Seems like Apple should upgrade the native player. I will keep using the new player and manually start PIP.
I can confirm. Thanks so much! This’ll work until Plex can fix it…
