Play synced Content on another iOS Device without internet
First Device ( with downloaded content) = iPhone XS with Plex 6.5 (18908)
Second Device (without downloaded content) = iPad Pro with Plex 6.5 (18908)
i try to play a synced movie or tv show from the first device to the second device. Both Apps crashes. Here are the tests that i ´ve made.
There are a few ways to start the media. Both device are able to browse the content from each other and both devices are alowed to work as a remote for the other one.
First Way:
Start the media from the first device via remote to play the video on the second device. Both devices are in the same network and internet is available.
Result:
The video starts playing. After a few seconds the plex app on the first device crashes. the video will play on the second device a little bit longer and stops then.
Second Way:
Start the media from the first device via remote to play the video on the second device. Both devices are in the same network and internet isn´t available.
Result:
The video starts playing. After a few seconds the plex app on the first device crashes. the video will play on the second device a little bit longer and stops then. In my mind there is no difference betwen the first way.
Third Way:
Start the media from the second device. In this case i choose the first device as source. Both devices are in the same network and internet is available.
Result:
The video starts playing. After a little bit longer time, the plex app on the first device crashes. the video will play on the second device a little bit longer and stops then.
Fourth Way:
Start the media from the second device. In this case i choose the first device as source. Both devices are in the same network and internet isn´t available.
Result:
The video starts playing. After a little bit longer time, the plex app on the first device crashes. the video will play on the second device a little bit longer and stops then. In my mind this option works the longest time before the first device crashes.
Can you repeat the problem and then after restarting each Plex app on each device and doing nothing else, email the logs to yourself and then post them here.
https://support.plex.tv/articles/201636593-ios-logs/
