Play to XBMC Chrome Extension
Hi to all,
I wanted to ask if it's possible to use the "Play to XBMC" Chrome Extension (https://chrome.google.com/webstore/detail/play-to-xbmckodi/fncjhcjfnnooidlkijollckpakkebden) with RasPlex.
As far as I know, the core of RasPlex is openelec, with this it should be possible.
I don't get a connection with the Extension but am unsure if it's not supported or if my settings are incorrect.
Configuration I tested:
IP: IP of the Raspberry
Port: 8080 (standard port)
Username: empty, "openelec"
Password: empty
Thanks for your help!
Regards
Could probably a developer tell me if this is possible or not?
A Simple Yes or No would be enough.
Thanks!
https://support.plex.tv/hc/en-us/articles/200392326-Using-the-Plex-It-Bookmarklet
