i already set up a plex sever, plex app on androidphone and also embeded the plex //xxx.xxx.xxx.xxx:32400/web/index.html on my own pache (hostet with apache),
My problem is that a normal pi with raspin delivers not that quality that i want to have. For this reason i installed rasplex (and it was awsome ).
But now i got troble to get a browser.
is there any app/plugin/update for rasplex wich give you the posibility to run a webbrowser inside of rasplex?!?
There is no work around, the nearest you’ll get is using Berryboot with a version of Raspbian installed alongside Rasplex, however you would have to quit Rasplex, allow Raspbian to boot, use the web browser, then quit Raspbian and boot Rasplex. Very ugly workaround!
i already have embeded rasplex into my own html - just the performance at webbroser is bad. Is there any recomended way to increase the rasplex web interface performance on a raspberry!?
