Playback Error on Raspberry pi 4
Server Version#: 1.19.4.2902
Player Version#: 1.12.0.1232-aacabe78
Plex Media Server Logs_2020-06-05_12-31-13.zip (4.1 MB)
Running Raspberry Pi 4 4gb, it gives a Playback Error when I’m trying to play anything.
Conversion failed. The transcoder failed to start up.
Please help, thanks!
From your logs:
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: analyzing media item 25
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): Direct Play is disabled
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): no direct play video profile exists for http/mp4/h264
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): no direct play video profile exists for http/mp4/h264/aac
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): selected sidecar subtitle stream cannot be direct played
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): Direct Streaming is disabled, so video stream will be transcoded
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): no remuxable profile found, so video stream will be transcoded
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - Scaled up video bitrate to 5199Kbps based on 1.500000x fudge factor.
Jun 05, 2020 12:29:58.275 [0xa99f6450] DEBUG - MDE: The Invisible Man (2020): selected media 1 / 25
Jun 05, 2020 12:29:58.276 [0xa99f6450] DEBUG - Streaming Resource: Adding session 0x2827600:kopqia2ve2p1hkabiwzwyjab which is using transcoder slot.  Used slots is now 1
Jun 05, 2020 12:29:58.276 [0xa99f6450] DEBUG - Streaming Resource: Added session 0x2827600:kopqia2ve2p1hkabiwzwyjab
Jun 05, 2020 12:29:58.276 [0xa99f6450] DEBUG - Streaming Resource: Reached Decision id=24 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=25 part=(id=25 decision=transcode container=mkv protocol=http streams=(Video=(id=1686 decision=transcode bitrate=5199 encoder=libx264 width=1920 height=800) Audio=(id=1687 decision=copy channels=6 rate=48000) Subtitle=(id=1548 decision=transcode bitrate=2147483647 encoder=ass languageCode=chi location=embedded))))
Jun 05, 2020 12:29:58.281 [0xb12fe450] DEBUG - Completed: [192.168.50.209:52510] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F24&mediaIndex=1&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=fo2zctse8ehl4rgdn17pldgf&offset=0&subtitles=auto&copyts=1&Accept-Language=en (8 live) TLS GZIP 42ms 3511 bytes (pipelined: 3)
Jun 05, 2020 12:29:58.542 [0xb1aff450] DEBUG - Auth: authenticated user 1 as charliezhang563@gmail.com
Jun 05, 2020 12:29:58.542 [0xa81f3450] DEBUG - Request: [192.168.50.209:52519 (Subnet)] GET /video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F24&mediaIndex=1&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=0&subtitleSize=100&audioBoost=100&location=lan&session=fo2zctse8ehl4rgdn17pldgf&offset=0&subtitles=auto&copyts=1&Accept-Language=en (9 live) TLS Signed-in Token (charliezhang563@gmail.com) (range: bytes=0-)
Jun 05, 2020 12:29:58.542 [0xa81f3450] DEBUG - Found session GUID of fo2zctse8ehl4rgdn17pldgf in session start.
Jun 05, 2020 12:29:58.542 [0xa81f3450] DEBUG - TranscodeUniversalRequest: using profile Plex Desktop
Jun 05, 2020 12:29:58.542 [0xa81f3450] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/24?checkFiles=1&includeBandwidths=1&offset=0&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=kopqia2ve2p1hkabiwzwyjab
Jun 05, 2020 12:29:58.542 [0xa81f3450] DEBUG - Auth: authenticated user 1 as charliezhang563@gmail.com
Jun 05, 2020 12:29:58.558 [0xa81f3450] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 05, 2020 12:29:58.558 [0xa81f3450] DEBUG - Selecting best audio stream for part ID 24 (autoselect: 0 language: en)
Jun 05, 2020 12:29:58.558 [0xa81f3450] DEBUG - Audio Stream: 1685, Subtitle Stream: -1
Jun 05, 2020 12:29:58.559 [0xa81f3450] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jun 05, 2020 12:29:58.559 [0xa81f3450] DEBUG - Selecting best audio stream for part ID 25 (autoselect: 0 language: en)
Jun 05, 2020 12:29:58.559 [0xa81f3450] DEBUG - Audio Stream: 1687, Subtitle Stream: 1548
Jun 05, 2020 12:29:58.562 [0xa81f3450] DEBUG - Cleaning directory for session fo2zctse8ehl4rgdn17pldgf ()
Jun 05, 2020 12:29:58.562 [0xa81f3450] DEBUG - Starting a transcode session fo2zctse8ehl4rgdn17pldgf at offset -1.0 (state=3)
Jun 05, 2020 12:29:58.563 [0xa81f3450] DEBUG - [Universal] Using local file path instead of URL: /mnt/rclone/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG/Plex Versions/Optimized for TV/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG (2020).mp4
Jun 05, 2020 12:29:58.563 [0xa81f3450] DEBUG - HTTP requesting GET http://127.0.0.1:32400/library/streams/1548?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 05, 2020 12:29:58.564 [0xa89f4450] DEBUG - Request: [127.0.0.1:34704 (Loopback)] GET /library/streams/1548 (10 live) GZIP Signed-in Token (charliezhang563@gmail.com)
Jun 05, 2020 12:29:58.568 [0xa89f4450] DEBUG - Content-Length of /mnt/rclone/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG/Plex Versions/Optimized for TV/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG (2020).zh.srt is 91511 (of total: 91511).
Jun 05, 2020 12:29:58.781 [0xa3ffd450] DEBUG - HTTP requesting GET https://plex.tv/services/pubsub/servers
Jun 05, 2020 12:29:58.816 [0xa6dfe450] DEBUG - [PlexRelay] Authenticated to 50.116.59.145 ([50.116.59.145]:443).
Jun 05, 2020 12:29:59.210 [0xa3ffd450] DEBUG - HTTP 200 response from GET https://plex.tv/services/pubsub/servers
Jun 05, 2020 12:29:59.627 [0xb1aff450] DEBUG - Auth: authenticated user 1 as charliezhang563@gmail.com
Jun 05, 2020 12:29:59.627 [0xa91f5450] DEBUG - Request: [192.168.50.1:56299 (Subnet)] GET /:/eventsource/notifications (11 live) TLS Signed-in Token (charliezhang563@gmail.com)
Jun 05, 2020 12:29:59.628 [0xa91f5450] DEBUG - Content-Length is -1 (of total: -1).
Jun 05, 2020 12:29:59.698 [0xa89f4450] ERROR - An error occurred reading the file: /mnt/rclone/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG/Plex Versions/Optimized for TV/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG (2020).zh.srt (5).
Jun 05, 2020 12:29:59.699 [0xa81f3450] ERROR - Error issuing curl_easy_perform(handle): 18
Jun 05, 2020 12:29:59.699 [0xa81f3450] WARN - HTTP error requesting GET http://127.0.0.1:32400/library/streams/1548?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (18, Transferred a partial file) (transfer closed with 91511 bytes remaining to read)
Jun 05, 2020 12:29:59.700 [0xa81f3450] ERROR - Error configuring transcoder: TPU: Failed to download sub-stream to temporary file
Jun 05, 2020 12:29:59.700 [0xa81f3450] DEBUG - Streaming Resource: Terminating session 0x2827600:kopqia2ve2p1hkabiwzwyjab which is using transcoder slot.  Used slots is now 0
Jun 05, 2020 12:29:59.700 [0xa81f3450] DEBUG - Streaming Resource: Terminated session 0x2827600:kopqia2ve2p1hkabiwzwyjab with reason Conversion failed. The transcoder failed to start up.
Jun 05, 2020 12:29:59.700 [0xaecff450] DEBUG - Killing job.
It appears you have ASS subtitles? ASS is converted to SRT.
The transcoder is failing during this conversion. It cannot write the SRT file.
(fail to download stream to temporary file)
Than’s for the reply! How can I solve this problem?
I tried to disable subtitle but I get “Conversion failed. The transcoder exited due to an error.”
Plex Media Server Logs_2020-06-05_15-08-27.zip (4.2 MB)
Where is this rclone file? Is it remote?
Jun 05, 2020 12:29:58.040 [0xb12fe450] DEBUG - HTTP requesting GET https://downloads.plex.tv/relay/relay_v1.pub
Jun 05, 2020 12:29:58.197 [0xa89f4450] ERROR - An error occurred reading the file: /mnt/rclone/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG/Plex Versions/Optimized for TV/The.Invisible.Man.2020.1080p.WEBRip.x265-RARBG (2020).zh.srt (5).
Jun 05, 2020 12:29:58.198 [0xa91f5450] ERROR - Error issuing curl_easy_perform(handle): 18
Jun 05, 2020 12:29:58.198 [0xa91f5450] WARN - HTTP error requesting GET http://127.0.0.1:32400/library/streams/1548?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (18, Transferred a partial file) (transfer closed with 91511 bytes remaining to read)
Jun 05, 2020 12:29:58.199 [0xa91f5450] ERROR - Error configuring transcoder: TPU: Failed to download sub-stream to temporary file
Jun 05, 2020 12:29:58.199 [0xa91f5450] DEBUG - Streaming Resource: Terminated session 0xb1b87cb8:kopqia2ve2p1hkabiwzwyjab with reason Conversion failed. The transcoder failed to start up.
Jun 05, 2020 12:29:58.199 [0xb2451450] DEBUG - Killing job.
It looks like your remote is failing you.
Thank you! Solved my problem, it was the issue with rclone.
