Server Version#: 4.156.0
Player Version#: Chrome on PC (everything is ok), Android 10.30.8.4222
I have choppy playback (looks like 8-10 fps) on some TV series on my Android TV box, while the fullhd or 4k movies are played ok. The same TV series are played ok on my PC through web. Connectivity is ok (1Gbps for both, server is on local lan, hw encoding enabled). Here are properties of media I tried to play:
Media
Duration 20:39
Bitrate 1160 kbps
Width 624
Height 352
Aspect Ratio 1.78
Video Resolution SD
Container AVI
Video Frame Rate PAL
Video Profile advanced simple
Part
Duration 20:39
File Dva.a.pol.chlapa.S09E01.DVDrip.XviD.SK-Snf.avi
Size 172.90 MB
Container AVI
Codec MPEG4
Bitrate 1032 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Codec ID XVID
Coded Height 352
Coded Width 624
Frame Rate 25 fps
Height 352
Level 5
Ref Frames 1
Width 624
Display Title SD (MPEG4)
Extended Display Title SD (MPEG4)
Codec MP3
Channels 2
Bitrate 128 kbps
Audio Channel Layout stereo
Sampling Rate 48000 Hz
Stream Identifier 1
Display Title Unknown (MP3 Stereo)
Extended Display Title Unknown (MP3 Stereo)
