Playback has stop due to multiple playback errors. Please check connection and try again
Server Version#: 1.26.1.5798
Player Version#: Roku and Web
Logs: Plex Media Server Logs_2022-05-18_14-10-12.zip (5.7 MB)
3.40 gigahertz Intel Core i7-3770
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
8192 kilobyte tertiary memory cache
64-bit ready
Multi Core (4 total)
Hyper-threaded (8 total)
Windows 7 Professional (x64) Service Pack 1 (build 7601.24546)
Install Language: English (United States)
System Locale: English (United States)
Installed: 4/6/2020 1:47:41 AM
32656 Megabytes Usable Installed Memory
Slot ‘DIMM3’ has 8192 MB (serial number D4A5285D)
Slot ‘DIMM1’ has 8192 MB (serial number 62C80000)
Slot ‘DIMM4’ has 8192 MB (serial number D4A527F8)
Slot ‘DIMM2’ has 8192 MB (serial number 61C80000)
Internet Provider: Xfinity (aka) Comcast
Voice and Data Modem: ARRIS Group, Inc. TG4482A Serial #: A8705D9CBC32
Hard Wired cat5 & Wireless
Plex / Roku errors:
Has been a issue for over a month.
This where it gets really strange. I have two TV’s Master Bedroom and TV Room
The TV room TV will not run movies, shorts or TV Series without getting the error
TV Room: RCA Roku TV
Master Bedroom: JVC with Roku Streaming Stick 4K
The Master Bedroom, works without the error. (Playback has stop due to multiple playback errors. Please check connection and try again.)
I have updated the Roku Plax software on both systems – No Change
I have updated The Roku software on both – No Change
On the RCA/Roku TV I have moved the Roku Streaming Stick 4K to the TV Room: No Change
I hope this gives you enough to work with, but if you need more let me know.
I also have fallowed a couple of the online fixes and the end results is always the same, master bedroom
System works like it should and the TV Room is still not working just like it should .
Let me say thanks for seeing and hopefully helping me to solve this issue
PS: I also Cleaned bundles & Optimized Database / with no good results
Well here it is …
ROKU Fix for: Playback has stop due to multiple playback errors. Please check connection
and try again
C:\Users\Wo***\AppData\Local\Plex Media Server\Logs
TcpTimedWaitDelay
https://docs.oracle.com/cd/E23507_01/Search.20073/ATGSearchAdmin/html/s1207adjustingtcpsettingsforheavyload01.html
https://wjw465150.github.io/blog/java/my_data/network/TcpTimedWaitDelay.htm
How to resolve a channel playback issue Roku
https://support.roku.com/article/208755548#section-4
I now have watched 4 episodes NCIS and 4 episodes of Chicago P.D.
and I’m about 2/3rds of the way thru Jane Got A Gun, and have not seen
and try again.
Hope this helps others!
See Yeah
