Playback issues on Sony Android TV
Server Version#: 1.30.0.6486 (Windows Server 2022)
Player Version#: 9.13.1.36459 have tried beta and regular app, no difference
Hi all, I have a TV show which consistently plays with a green line down the middle on every episode, and a movie which simply says An error occurred while attempting to play this video. Please check your connection and try again. This has happened in the past and I’ve messed with all the quality and encoding settings found referenced on various Google searches and never been able to fix it. Oddly, this issue only ever affects my Sony TV, I’ve never found media that doesn’t play perfectly in my browser or on my Android phone.
Looking at the logs there doesn’t seem to be any warnings or errors that explain this. Any ideas what could be causing it?
Photo of green line: [mod-edit: tagged image so it’ll properly show]
Photo of green line
Media Info - TV Show with green line
General
Unique ID                                : 79496417583072175532978099372252842604 (0x3BCE73FEFB88EC067ED811395159CA6C)
Complete name                            : f:\tv shows\<hidden for privacy>\season 1\<hidden for privacy>.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 1.67 GiB
Duration                                 : 40mn 43s
Overall bit rate                         : 5 854 Kbps
Writing application                      : mkvmerge v62.0.0 ('Apollo') 64-bit
Writing library                          : libebml v1.4.2 + libmatroska v1.6.4
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L4@Main
Codec ID                                 : V_MPEGH/ISO/HEVC
Duration                                 : 40mn 43s
Bit rate                                 : 5 209 Kbps
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 24.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.105
Stream size                              : 1.48 GiB (89%)
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : E-AC-3
Format/Info                              : Audio Coding 3
Format settings, Endianness              : Big
Codec ID                                 : A_EAC3
Duration                                 : 40mn 43s
Bit rate mode                            : Constant
Bit rate                                 : 640 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Frame rate                               : 187.500 fps (256 spf)
Compression mode                         : Lossy
Stream size                              : 186 MiB (11%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Duration                                 : 36mn 20s
Bit rate                                 : 51 bps
Count of elements                        : 383
Stream size                              : 13.6 KiB (0%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : UTF-8
Duration                                 : 36mn 39s
Bit rate                                 : 66 bps
Count of elements                        : 556
Stream size                              : 17.9 KiB (0%)
Title                                    : SDH
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3 - #36 for other languages, removed to keep this short
Media Info - Movie, won't play
General
Unique ID                                : 292413716611431589669354657124725121196 (0xDBFCD552F64F6D246B3610810DC160AC)
Complete name                            : f:\movies\<removed for privacy>\<removed for privacy>.mkv
Format                                   : Matroska
File size                                : 9.74 GiB
Duration                                 : 1h 34mn
Overall bit rate                         : 14.8 Mbps
Encoded date                             : UTC 2022-06-02 13:01:40
Writing application                      : mkvmerge v68.0.0 ('The Curtain') 64-bit
Video
Format                                   : HEVC
Format profile                           : Main 10@L5@High
Duration                                 : 1h 34mn
Bit rate                                 : 14.4 Mbps
Width                                    : 3 840 pixels
Height                                   : 1 600 pixels
Display aspect ratio                     : 2.40:1
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.098
Stream size                              : 9.49 GiB (97%)
Default                                  : Yes
Forced                                   : No
Color primaries                          : BT.2020
Transfer characteristics                 : SMPTE ST 2084
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000.0000 cd/m2
Maximum Content Light Level              : 1071 cd/m2
Maximum Frame-Average Light Level        : 215 cd/m2
Audio
Format                                   : AC-3
Mode extension                           : CM (complete main)
Codec ID                                 : A_AC3
Duration                                 : 1h 34mn
Bit rate                                 : 384 Kbps
Frame rate                               : 31.250 fps (1536 spf)
Stream size                              : 259 MiB (3%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Text
Format                                   : UTF-8
Duration                                 : 1h 34mn
Bit rate                                 : 41 bps
Count of elements                        : 1179
Stream size                              : 28.9 KiB (0%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Logs, from a session where I play a couple of the episodes with green line, then attempt to play the movie.
Debug
Here, due to forum character limit: https://pastebin.com/3qASh7AD
Info
Jan 10, 2023 11:35:18.290 [15092] Info — [Req#1eeb7] AutoUpdate: no updates available
Jan 10, 2023 11:36:55.243 [2480] Info — [Req#1f55e/Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Jan 10, 2023 11:36:55.292 [2480] Info — [Req#1f55e/Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Jan 10, 2023 11:36:55.340 [2480] Info — [Req#1f55e/Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Jan 10, 2023 11:36:55.389 [2480] Info — [Req#1f55e/Transcode] [FFMPEG] - MFT name: 'Microsoft AAC Audio Encoder MFT'
Warning
Jan 10, 2023 11:35:18.951 [8672] Warning — [Req#1eeef] QueryParser: Invalid field 'IncludeExternalMedia' found, ignoring.
Jan 10, 2023 11:35:24.658 [8672] Warning — [Req#1ef26] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:35:29.807 [8672] Warning — [Req#1ef72] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:35:30.564 [15092] Warning — [Req#1ef84] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:00.660 [4920] Warning — [Req#1f11c] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:01.418 [8672] Warning — [Req#1f176] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:13.229 [0688] Warning — [Req#1f259] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:39.395 [0688] Warning — [Req#1f410] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:40.438 [0688] Warning — [Req#1f42b] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:42.007 [0688] Warning — [Req#1f446] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:36:42.801 [0688] Warning — [Req#1f47e] QueryParser: Invalid field 'IncludeExternalMedia' found, ignoring.
Jan 10, 2023 11:36:55.141 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:36:55.193 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:36:55.237 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:36:55.286 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:36:55.334 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:36:55.383 [2480] Warning — [Req#1f55e/Transcode] Codecs: avcodec_open2 returned -40 for encoder 'h264_mf'
Jan 10, 2023 11:37:20.758 [2480] Warning — [Req#1f812/Transcode] Got a request to stop a transcode session without a valid session GUID.
Jan 10, 2023 11:37:21.172 [2480] Warning — [Req#1f851] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:37:24.871 [11336] Warning — [Req#1f8b1] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 10, 2023 11:37:24.871 [11336] Warning — [Req#1f8b1] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:37:24.884 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 10, 2023 11:37:24.884 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:37:24.884 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'sectionID' found, ignoring.
Jan 10, 2023 11:37:24.888 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jan 10, 2023 11:37:24.888 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Jan 10, 2023 11:37:24.888 [2480] Warning — [Req#1f86c] QueryParser: Invalid field 'sectionID' found, ignoring.
Error
Jan 10, 2023 11:35:17.552 [8672] Error — [Req#1eeba] Unknown metadata type: folder
Jan 10, 2023 11:35:18.464 [15092] Error — [Req#1eee4] Unknown metadata type: folder
Jan 10, 2023 11:35:19.244 [8672] Error — [Req#1eef6] Unknown metadata type: folder
Jan 10, 2023 11:36:37.889 [11012] Error — Session 05F26498 terminated
Jan 10, 2023 11:36:55.075 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.075 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.116 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.142 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.142 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.145 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:36:55.147 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.147 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.192 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.193 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.193 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.196 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:36:55.197 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.197 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.236 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.237 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.237 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.240 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:36:55.246 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.246 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.285 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.286 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.286 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.289 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:36:55.295 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.295 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.333 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.335 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.335 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.337 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:36:55.343 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.343 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.381 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - could not create MFT
Jan 10, 2023 11:36:55.383 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Jan 10, 2023 11:36:55.383 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jan 10, 2023 11:36:55.386 [2480] Error — [Req#1f55e/Transcode] [FFMPEG] - Failed to create Direct3D device
Jan 10, 2023 11:37:21.171 [2480] Error — [Req#1f851] Unknown metadata type: folder
Jan 10, 2023 11:37:24.870 [11336] Error — [Req#1f8b1] Unknown metadata type: folder
Is the Plex app for Android TV pretty much abandonware at this point? I notice many similar questions have no reply or acknowledgement and all the bugs don’t seem to exist on other platforms.
