Server Version#: 1.23.2.4656
Player Version#: 8.18.1.25719
Hi there!
Since upgrading my phone from Android 10 to Android 11, I’ve noticed that the playback notifications from Plex get stuck in the new playback area which was introduced with Android 11. I can’t remove them manually, and it’s not possible to open the Plex app and clear the playback from there either since the playback data within the app is already cleared. This error will get stuck for days and usually gets cleared when I reboot the phone, but after a few more uses new items will get stuck.
I’m mainly using Plex for TV Shows and Movies so it’s mainly these two where I’ve seen the issue occur.
I searched for similar topics on this forum and found multiple entries from 2-4 years ago but they are all closed without mentioning a solution.
I’m using a OnePlus 7 phone with the latest available OS version (Oxygen OS 11.0.1.1.GM57BA), the latest version of the Plex app and the latest version of the Plex Media Server.
I will attach two images taken seconds apart which will show you the issue..
Yeah, it seems to have been an issue for quite some time now… I found multiple threads about this prior to creating my own, but all of them were closed since people stopped posting in them. I must have overlooked the thread you refered to, because I didn’t see it.
I don’t know how to get their attention, but this is actually really annoying.
Hi, I’m having the same issue so I guess the least I can do is to put this thread as favorite and comment on it. I hope this gets more visibility to it. Cheers
I have noticed that the issue will also occur in the following scenario:
Start playback of an episode, watch the whole thing and then crucially → wait for the countdown to start the next episode. From then on, both episodes will show up in the notification bar.
Replying to keep this thread alive, still a problem on my Motorola Edge+ Android 11.
My problem is bigger, though, in that the Android 11 media controls don’t always appear after Plex has started playing a stream, I sometimes have to restart Plex a few times, pause/play a few times, etc. Haven’t figured out what pattern eventually gets them to appear.
