on android in the playback you have the option for playback speed but when you press it id does not show up it just closes everything. i seems t is opening something off screen because if you hit the back button you get back to the playback settings menu.
Yeah, that screen wrongly hides itself. You should be able to slide up from the very bottom of the screen to bring it up.
