Server Version#: 1.21.1.3830
Player Version#: 5.6.1
TV Model: Samsung QE55Q70R
TV Firmware#: 1372
Lots of files play correctly on my TV, but I have got a whole TV show causing issues. When I click play, the stream starts and both Plex dashboard and tautulli reports Direct Play, but there is no audio and after few seconds the stream stops without displaying any error. Plex app returns to media selection, proposing the next episode like I finished watching the previous one.
I enabled “Log to server” from the TV, and you’ll find the logs here: Plex-Server+TV-Logs.txt (13.1 KB)
It appears that you don’t let your server perform the in-depth analysis. I recomend you to activate this (if your media storage is not in the cloud, that is).
I didn’t find a way to force an in-depth analysis, but I toggled it on and will wait for the next maintenance (got some users streaming movies at the moment so I don’t want to force a maintenance).
I tested the remuxing suggestion, and it worked! Do you know if there is a way to fix the MP4 instead of remuxing all episodes to MKV?
