Issue:
The tvOS app’s failure to follow the visual vocabulary of the other Plex clients, makes it difficult to see which episodes of television shows have not been watched.
Actual Behavior:
When viewing a Television Season, “played” shows display a green “tick” icon over their thumbnail. “Not played” shows display no visual indicator.
Expected Behaviour:
To be consistent with the Plex Web, and iOS App - “played” episodes should show no indicator - and “Not played” episodes should show a yellow triangle.
All things will be changing to the new behavior (green check for played). other TV clients (Roku, Android TV, smart tv’s) already do the same. I don’t think the mobile apps have changed yet but they should be afaik
I wish the Plex team would make this easier to see. The tiny green check has been a struggle. The yellow across the corner was so much easier to see. Maybe you could make the green dot bigger.
