Player crash playing 1280x720 live TV
I’m running Plex 1.9.4.4325 in my Ubuntu 16.10. All channels on my HDHomeRun Dual and Connect record without issue and play on the media player without issue.
I can watch all channels without issue through the web browser interface.
I can also DVR any channels without issue, including my local fox channel.
I can watch all channels on my ShieldTV (hardwired) without issue except for the local fox channel, which happens to also be the lowest channel number. When I attempt to play that channel I get “An error occurred while attempting to play this video. Please try restarting both the Plex Media Server and this app.”
I can watch all channels on my android phone also without issue over wifi except for the local fox channel as well. It also gets the same error.
I can watch all channels on my iPhone also without issue over wifi except for the local fox channel as well. It gets this error, “Couldn’t create the playback session for this item”
No amount of rebooting server or devices helps.
Anyone else having an issue like this? It doesn’t seem like it’s a server problem because it records and the web browser interface on a different computer play the live channel fine.
More info in second post
Here’s the failure from my Android TV box.
10-25 20:23:32.979 w: [FF] AVC configuration parser failed, failing back to using the original initialisation data.
10-25 20:23:32.980 i: [FF] Container[hls,applehttp] No Title - 0 kbps, 419 hr 57 min [CT: 1508981016277us, ST: 10033367us, SRT: -9223372036854775808us].
10-25 20:23:32.981 i: [FF] VideoStream[0-h264] 1280x720 [SAR 1:1, DAR 16:9]. H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 - Unknown Profile (video/avc), 9.5 Mbps 419 hr 57 min 59.94fps, No Title / Unknown (null), 1 / 36 bytes, .
10-25 20:23:32.981 i: [FF] AudioStream[1-ac3] 6 channels over 1551 (5.1(side)), 48000 Hz, 0,0 padding. ATSC A/52A (AC-3) - Unknown Profile (audio/ac3), 9.5 Mbps 419 hr 57 min 0.00fps, No Title / Unknown (null), 0 bytes, .
10-25 20:23:32.989 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
10-25 20:23:32.989 i: [FF] Audio decoder supports ac3 (audio/ac3).
10-25 20:23:32.990 i: [FF] Audio decoder supports ac3 (audio/ac3).
10-25 20:23:32.991 i: [FF] Video decoder doesn’t support h264 (video/avc).
10-25 20:23:32.991 i: [MediaTrackSelector] Video selection was filled by id=0, mimeType=video/avc, bitrate=9514000, res=1280x720, fps=59.94006.
10-25 20:23:32.991 i: [MediaTrackSelector] Audio selection was filled by id=1, mimeType=audio/ac3, bitrate=9514000, channels=6, sample_rate=48000.
10-25 20:23:32.992 i: [FF][MediaPeriod] Selecting tracks.
10-25 20:23:32.992 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
10-25 20:23:32.992 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
10-25 20:23:32.992 i: [BufferHelper] Segment count: 3276
10-25 20:23:33.006 i: [Exo2VideoPlayer] Switching video surface to use a standard surface.
10-25 20:23:33.028 e: [FF] Video decoder encountered an error whilst feeding the decoder at 0us.
10-25 20:23:33.035 e: [Exo2VideoPlayer] Player error detected
10-25 20:23:33.036 e: An exception occurred: com.google.android.exoplayer2.d
10-25 20:23:33.036 e: Stacktrace: com.google.android.exoplayer2.d
at com.plexapp.plex.ff.decoder.NativeRenderer.render(SourceFile:173)
at com.google.android.exoplayer2.k.g(SourceFile:574)
at com.google.android.exoplayer2.k.handleMessage(SourceFile:350)
at android.os.Handler.dispatchMessage(Handler.java:98)
at android.os.Looper.loop(Looper.java:154)
at android.os.HandlerThread.run(HandlerThread.java:61)
Caused by: com.plexapp.plex.ff.decoder.NativeDecoderException: [FF] Video decoder failed to decode.
at com.plexapp.plex.ff.decoder.NativeDecoder.feed(SourceFile:398)
at com.plexapp.plex.ff.decoder.NativeDecoder.decode(SourceFile:333)
at com.plexapp.plex.ff.decoder.NativeDecoder.run(SourceFile:171)
at java.lang.Thread.run(Thread.java:761)
10-25 20:23:33.049 i: [video] Error detected before playback
10-25 20:23:33.087 i: [FF] Native decoder is being released.
10-25 20:23:33.088 i: [TranscodeSession] Stopping…
10-25 20:23:33.088 i: [FF] Releasing demuxer.
10-25 20:23:33.089 e: [Video Player] A recoverable error occurred while attempting to play: /livetv/sessions/73c64991-88cc-427a-ab68-4075a59d8f16.
10-25 20:23:33.089 e: [Video Player] Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure the server is available and retry.
