Player never stops -Android TV 8.0.0.17168
Hello,
Since the last 2 betas, I have this weird bug where the player never stops. When the video is supposed to end, the last frame is displayed, but instead of stopping, the player keep showing it, and the “timeline” goes negative (-1s, -2s, etc), like a never ending video.
The videos are fine btw, no problem with an other player. All is fine too with the plexforkodi addon, so the problem is not the server imo.
Am I the only one with this ?
Thx.
I’m seeing something similar. At the end of an TV episode the Up next screen doesn’t come up, just a freeze frame of the end of the file.
Edit: It appears as thought he Android app is not feeding back it’s position to server correctly. Looking at the Tautulli logs it shows the TV program played but never got past the start and shows as having no duration played.
Noticing this too. Was trying some dolby atmos demo clips and after the 1 min clip finishes the video freezes. If I bring up the info page I see it counting seconds again from the beginning. Like it’s trying to loop the video a second time but there’s no audio and the video is frozen on the last frame of the clip.
It may be fixed in the latest Beta out today. I juts played a show and after it finished it went to the next Ep screen.
