Server Version#: 1.21.3.4021
Player Version#: Web - 4.52.1, Firestick - latest
As the title suggests, I think my issues are boiling down to mkv h.265 files.
I have a firestick attached to my samsung TV, but I’m also seeing the same behavior when using the web player from my laptop.
Each time I try and play one of these files, within 5-10 seconds an error will come up saying something went wrong and the plex server will completely crash.
I currently have the plex service running, so I can see it stop, then countdown for a 10 second pause prior to starting back up. I have closed the service and just ran plex as the logged in user but that didn’t seem to change anything. I had seen a few posts about plex running as a service possibly having issues using quicksync decoding, so I figured it was worth a shot.
When I look at some of the logs, specifically the server log it seems to only contain info after plex started back up again after the crash, nothing prior to that.
If I watch the console output I can see some errors come up but since plex crashes right away that is hard to glean any info from before it blinks out.
I used to have plex running on a VM, and at least the 1080 mkv h.265 files seem to play fine. About 4 months ago I migrated everything over to a fresh W10 optiplex 7060 machine. Haven’t really tried playing anything h.265 since the conversion so I’m just discovering this now.
I had searched the forums for topics on playing 265 format files, and I saw some posts of about the machines sometimes not being powerful enough to transcode. But nothing saying nothing 265 will play. So I’m guessing this is an issue just with my setup.
Any ideas on this?
