I would like it, for when you are watching a list of videos, that the 10 seconds it gives you between episodes happens during the last 10 seconds of the episode you are watching. So basically by the time the last episode finishes completely, the next episode starts right away instead of having to wait the extra 10 seconds. Or even a way where I can set the amount of time manually then maybe set it to zero. If I can as well, turn off the feature where it makes you push play after the x number of episodes to stop from playing too many episodes in a row
+1 for this, would be good for TV shows, although might get annoying if I can’t find a decent time for all my rips.
Since I’ve started to use plex and moving from KODI, I miss this a lot.
For me, the Next Episode feature simply doesn’t work at all…plex simply plays the same episode again! I have to go back out to the particular season and then find the next episode. Surely this must be a bug or something as it has never worked right for me.
Add my vote to this. An option to play the next available episode seems like it should be easy. Currently I either have exit the episode screen by selection the season, browse to the next episode, select it, and then play it. Since you have already identified the next episode in the On Deck, why not put the next on deck right on the episode screen when it finishes?
I would like this to be easier to access. But in my experience, if you press play on a whole season, it will play the episodes you havent seen, and continue from one to the next.
It seems that if you press play on a single episode (like most people do) plex will think that you only want to see that episode.
So I vote for this aswell, but knowing its allready in - I would like it to be the default style of play instead.
So it is more for when you push play on the whole season the system sets a timer in between the episodes even to say that it is already going to play the next episode but counts down before it does to allow you to stop it from autoplaying.
duplicate feature request
closing
