Playlist Creation Confusion
Hello, trying to create (or recreate) music playlists inside Plex. When selecting a song and add to playlist I only have the option of my first five alphabetized playlists and cannot scroll down to reach other lists. I am sure this isn’t the case. Can someone steer me towards the right button?
C
This doesn’t belong in Forum Feedback, but is it possible that some of your playlists are smart playlists? Those will not be listed when you are manually adding tracks to playlists, because smart playlists are populated automatically according to the filters you chose when you created them.
Manually adding tracks to playlists gives me a scrollable list of all non-smart playlists, so I can’t reproduce what you’re describing.
