Sync option missing from Playlist’s on the Android app.
Can anyone else concur ?
This has never worked for me. Syncing music playlists was my number one reason for getting plex pass too…Guess I won’t be renewing at the end of the year, although I would gladly buy a lifetime pass if that feature were working as it is supposed to.
You cannot sync playlist in Android yet. It’s being worked on.
@MovieFan.Plex Is there any update on this since June? For the top skills at Plex, it seems to be taking some time to get this implemented.
Playlist Sync is currently available in the Beta build. If you would like to try it join join the Beta team, https://forums.plex.tv/discussion/220582/help-us-beta-test-the-android-app.
I did request to join (twice actually). I haven’t seen it show up for me in the “beta” section of the Google Play store. I can only assume this means my request hasn’t been approved/accepted by Plex?
The Beta is open to everyone, there is no approval needed. You should have gotten a confirmation from Google after singing up. It may take a little while for the beta to be available, but it will show up as a regular update in the store. The Beta will override the regular store version.
