Playlists / Continuously Play
Is there a way to disable playlists / continuously play, it is annoying that it will auto start the next unwatched episode without being able to configure if one wants it to do this or not.
I wonder how you had it in the first place!  I want that feature (both with a way to control it, with a pre-play screen that appear before the current episode finish playing, like Netflix does).
In my case, I aways have to start the next episode manually.
if u use the play button it will play continuously, if u enter the pre play screen and use the play button it will only play that episode (if i remember correctly)
if u use the play button it will play continuously, if u ennter the pre play screen en use the play button it will only play that episode (if i remember correctly)
I'd rather have an on/off option, but this will do.
Thanks.
I guess in your situation a global option would be noice for you. Personally now that it has been implemented I cannot live without continuous play. It’s like watching tv shows, episode after episode without having to change channels especially with playlists. Load a playlist up and hit shuffle and you could watch tv/ movies for days/weeks/months all commercial free.
