Playstation PS4 Pin Entry
Hello everyone,
I have a problem connectiong my PS4 with my PMS running on a Synology NAS.
All other devices can connect.
After downloading the app on the PS i enter the confirmation link - which is accepted.
Then I am forwarded to the login screen where I should choose the user and enter the Pin.
Both is not possible.
No entry is accepted - only PS Button works.
How can I fix this?
Thanks for your help!
Solved - switch from secure to insecure connection.
Now it is working
