Please fix the folder option, i got a lot of files in one folder. Then when i search i use the folder option instead of movies. So that i can browse true the files. But after the update when u go into the map / folder then u see movies again instead of de maps / folders. I want also to scroll in maps / folders witch will lie underneath the top map.
