Please help save servers
I have a samsung led from 2013 and plex does not save the server data every time I log out.
They could help me. how to make
thank you
I’m confused. Can you explain your problem more?
It is important to exit the SmartHub app by pressing Left on the home screen and then exit.
If you however just press the SmartHub button on your remote, you are ‘killing’ the app. Which can lead to losing settings.
The problem is accessing remotely on samsung tv. I put the server xxx.xxx.xxx.xxx on port 32400 and it works.
I leave the plex and re-enter does not find the server. I have to write server again.
Samsung tv does not save server on plex.
thank you
yes I leave in left and not save the servers in the plex
