Hi. Whit the last player (10960). Whenever I play a 4k mkv movie with a .srt subtitle, it does not work. I need to turn off subtitles. Play the movie and in the menu, activate the subtitle. it’s still the same with (11058).
Thx
Thx
Is it an HDR video?
Yes.
General
Unique ID : 299315231806063679004393584603398520648 (0xE12E044B57EF39DBBBFDB7577191BF48)
Complete name : Z:\V08\1-Movies\1-Full EN-FR\Mission Impossible - Fallout (2018)\Mission Impossible - Fallout (2018).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 69.2 GiB
Duration : 2 h 27 min
Overall bit rate mode : Variable
Overall bit rate : 67.2 Mb/s
Movie name : MISSION__IMPOSSIBLE_FALLOUT.Title800
Encoded date : UTC 2018-12-01 07:04:50
Writing application : mkvmerge v25.0.0 (‘Prog Noir’) 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 61.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.309
Stream size : 63.3 GiB (91%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio #1
Format : TrueHD
Format profile : TrueHD+Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 5 026 kb/s
Maximum bit rate : 8 175 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 5.17 GiB (7%)
Language : English
Default : No
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 675 MiB (1%)
Language : French
Service kind : Complete Main
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 32 min 10 s
Bit rate : 1 b/s
Count of elements : 19
Stream size : 426 Bytes (0%)
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Duration : 2 h 1 min
Bit rate : 0 b/s
Count of elements : 13
Stream size : 319 Bytes (0%)
Language : French
Default : No
Forced : Yes
Menu
00:00:00.000 : en:(01)00:00:00:000
00:10:37.011 : en:(02)00:10:37:011
00:17:11.405 : en:(03)00:17:11:405
00:26:57.240 : en:(04)00:26:57:240
00:35:56.654 : en:(05)00:35:56:654
00:49:18.413 : en:(06)00:49:18:413
01:00:00.805 : en:(07)01:00:00:805
01:10:23.719 : en:(08)01:10:23:719
01:17:07.289 : en:(09)01:17:07:289
01:28:28.469 : en:(10)01:28:28:469
01:39:09.652 : en:(11)01:39:09:652
01:46:26.546 : en:(12)01:46:26:546
01:55:45.563 : en:(13)01:55:45:563
02:03:10.591 : en:(14)02:03:10:591
02:14:00.907 : en:(15)02:14:00:907
02:19:48.088 : en:(16)02:19:48:088
02:27:24.669 : en:(17)02:27:24:669
Hi everyone.
I try whit the new build 11125. It’s work really great.
Thx
