Plex 1.40: Error while decoding stream #0:1: No space left on device , is the bug back?
also, gave the plex user all permission
when leaving the folder setting, empty, i believe Plex is using this folder, as you can see, enough space left here… , no quote enabled
Do me a favor,
  1. with DEBUG logging still on
  2. Restart PMS
  3. Let it sit completely idle for 3 minutes
  4. Download the server logs
  5. Attach here.
Here you go:
Plex Media Server Logs_2024-05-11_20-05-48.zip (1.5 MB)
Thank you . That confirmed a lot of things it’s not.
If the bug were back, everyone would have reported by now.
My first thought is something might have damaged your codecs with DSM updates.
(weird but i’ve seen it)
Stop PMS
Delete the contents of the Codecs directory
Start PMS
Play something without Dolby
Then one by one, play things more complex.
Hmm, that didnt help, emptied that folder, the files were indeed redownloaded
But every episode/movie, tried several, all differen codecs, as soon as i transcode, i see the error :frowning:
Damn it. There is something uniquely wrong there with your machine.
I’ll figure it out. I need to experiment with my machine.
Checking your PlexMediaServer shared folder and where you put the transcoder temp folder (if you use it)
Make 100% certain to turn off quota.
The default file system watches is 65536 on DSM 7.
If you have not changed this value then the problem is not there as you do not have that many monitored folders.
DID you adjust that value and make a mistake?
No, quota is not enabled,and didn’t change any setting … :slight_smile:
i also see this:
and
maybe the bug is just back? i dont think it has anything todo with freespace, that error is unrelated, it was also on the previous bugs it seems
Hey, do you maybe have an update for me?
Thnx
Hey @ChuckPa , do you have update for me? Can I maybe submit this somewhere as an issue?
I can’t reproduce it.
Can you refresh my memory please?
  1. Container compose or docker run spec
  2. DEBUG logs of PMS start and it failing?
no, i dont use container or docker, its the synology package , i uploaded logs already in this thread…
I’m going to try and repro here again.
I’ll use the native package on my DS418 (which has 1GB of RAM)
saw a new version, but still same issue :-
You are currently running version 1.40.2.8395 on the server “DS423+”. Version 1.40.3.8555 is now
Hey, you have an update for me?
Tested same movie again , with latests updates, the error is now different?
can be helpfull maybe?
[Req#fa4cc/Transcode/v8gro6hh1tehw9ooej85hpag/10efd071-5564-4aca-93fa-cff4ff377052] [truehd_eae @ 0x7f8a0f865b00] error reading output: -1313558101 (Unknown error occurred)
[Req#fa4ac/Transcode/v8gro6hh1tehw9ooej85hpag/10efd071-5564-4aca-93fa-cff4ff377052] Error while decoding stream #0:1: Unknown error occurred
