So just installed Plex 9 KUDOS!!! Its snappy and just great. Love every bit of work you guys put into the new version.
I have a couple questions that I can’t figure out. The first one is how do you edit the title of a movie if Plex has scanned it and named it wrong? I used to be able to hit “C” and Edit Title now thats not an option so if someone could let me know how to do that I would appreciate it.
The second question is how do you get the Plex Media Server to stop launching at startup? I looked for a toggle in the advanced preferences but couldn’t find anywhere to turn it off. I also don’t see it in my login under my accounts tab so that would be helpful.
Thanks for the help
- in the plex media manager, right click the movie and hit “Fix Incorrect Match”, and if the correct one is not on the list, hit the search button and enter the title to search for.
- that one is inside of plex, in prefrences/system/media server, disable the “always running” checkbox.
Ok, so I have another question. What controls the order in which the Media Manager scans the files? It doesn’t appear to go in a logical progression from the first file in a directory of TV shows to the last one. At first it looked like it was taking the first file in each folder then repeating with the second in each folder, etc. Can one of the devs shed some light on this?
