Plex after recording doesn't move into correct directory and disappears from library
Server Version#: 1.29.1.6276
Hi Everyone,
After my recording successfully finishes in Plex it stays in the ./grab folder and does not get moved into a show folder is this correct by design? When it stays in the ./grab folder it disappears from my library even though the ./grab folder is in my primary library folder. Not sure since this is a hidden folder it does not get scanned properly by the library manager? Should the Plex Media Server be moving it into the TV Show Folder? Below is a copy of a log from a finished recording.
Oct 05, 2022 23:00:00.585 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Recording for 'Big Sky - E3 - A Brief History of Crime' on channel 5fc76bf5a05ef8002e7a8a26-5fc705f6a05ef8002e616210 stopped with status complete.
Oct 05, 2022 23:00:00.585 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Using recording status.
Oct 05, 2022 23:00:00.586 [0x14a94d710b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Cleaning directory for session 63835c45-b958-418d-a029-bbd58c9da26e (/config/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-63835c45-b958-418d-a029-bbd58c9da26e)
Oct 05, 2022 23:00:00.586 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Activity: updated activity 920242dc-8807-48f9-ae99-ea3491623614 - completed 100.0% - Recording
Oct 05, 2022 23:00:00.587 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Activity: updated activity 920242dc-8807-48f9-ae99-ea3491623614 - completed 100.0% - Recording
Oct 05, 2022 23:00:00.587 [0x14a949ef4b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Activity: updated activity 38540f19-bff1-4443-ae95-bbc7313f3090 - completed 50.0% - Refreshing Sub
Oct 05, 2022 23:00:00.587 [0x14a95855ab38] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 2782 is -9 (signal: Killed)
Oct 05, 2022 23:00:00.587 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Grabber: Freed a tuner on device://tv.plex.grabbers.hdhomerun/132236E5 (now 3 available)
Oct 05, 2022 23:00:00.592 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [MI] Opening input file: "/media/tvshows/.grab/2d670680b3f82705139140b1ed5d976763643b30-ac6b423a4e3ad886f1d8b9a9ee101ea789b0b178/Big Sky (2020) - S03E03 - A Brief History of Crime.ts"
Oct 05, 2022 23:00:00.592 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - Opening '/media/tvshows/.grab/2d670680b3f82705139140b1ed5d976763643b30-ac6b423a4e3ad886f1d8b9a9ee101ea789b0b178/Big Sky (2020) - S03E03 - A Brief History of Crime.ts' for reading
Oct 05, 2022 23:00:00.592 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - Setting default whitelist 'file,crypto,data'
Oct 05, 2022 23:00:00.593 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - Format mpegts probed with size=2048 and score=50
Oct 05, 2022 23:00:00.593 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - stream=0 stream_type=1b pid=100 prog_reg_desc=
Oct 05, 2022 23:00:00.593 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - stream=1 stream_type=81 pid=101 prog_reg_desc=
Oct 05, 2022 23:00:00.593 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - stream=2 stream_type=81 pid=102 prog_reg_desc=
Oct 05, 2022 23:00:00.593 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - Before avformat_find_stream_info() pos: 0 bytes read:32768 seeks:0 nb_streams:3
Oct 05, 2022 23:00:00.594 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - All programs have pmt, headers found
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 7(SPS), nal_ref_idc: 3
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 8(PPS), nal_ref_idc: 3
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 5(IDR), nal_ref_idc: 3
Oct 05, 2022 23:00:00.596 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - Format yuv420p chosen by get_format().
Oct 05, 2022 23:00:00.598 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - no picture
Oct 05, 2022 23:00:00.607 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.607 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.607 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Oct 05, 2022 23:00:00.608 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - no picture
Oct 05, 2022 23:00:00.612 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.612 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.612 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Oct 05, 2022 23:00:00.615 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.615 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.616 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Oct 05, 2022 23:00:00.623 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.623 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.623 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Oct 05, 2022 23:00:00.626 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.626 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.626 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Oct 05, 2022 23:00:00.628 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.628 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.628 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 0
Oct 05, 2022 23:00:00.632 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.632 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.632 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Oct 05, 2022 23:00:00.635 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 9(AUD), nal_ref_idc: 0
Oct 05, 2022 23:00:00.635 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 6(SEI), nal_ref_idc: 0
Oct 05, 2022 23:00:00.635 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - nal_unit_type: 1(Coded slice of a non-IDR picture), nal_ref_idc: 2
Oct 05, 2022 23:00:00.638 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - All info found
Oct 05, 2022 23:00:00.638 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - rfps: 59.000000 0.008176
Oct 05, 2022 23:00:00.639 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - rfps: 60.000000 0.000033
Oct 05, 2022 23:00:00.639 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - rfps: 120.000000 0.000134
Oct 05, 2022 23:00:00.639 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - rfps: 240.000000 0.000535
Oct 05, 2022 23:00:00.639 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - rfps: 59.940060 0.000000
Oct 05, 2022 23:00:00.643 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [FFMPEG] - After avformat_find_stream_info() pos: 0 bytes read:708752 seeks:2 frames:145
Oct 05, 2022 23:00:00.643 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [MI]  *  [mpegts h264/ac3] Duration: 7377744ms, 1280x720 (1.777778) 59.940fps, bitrate=5611kbps, audio channels=6, optimizedForStreaming=0 ("/media/tvshows/.grab/2d670680b3f82705139140b1ed5d976763643b30-ac6b423a4e3ad886f1d8b9a9ee101ea789b0b178/Big Sky (2020) - S03E03 - A Brief History of Crime.ts")
Oct 05, 2022 23:00:00.643 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [MI] Chapters had generic titles, clearing.
Oct 05, 2022 23:00:00.643 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] [MI] Closing input file: "/media/tvshows/.grab/2d670680b3f82705139140b1ed5d976763643b30-ac6b423a4e3ad886f1d8b9a9ee101ea789b0b178/Big Sky (2020) - S03E03 - A Brief History of Crime.ts"
Oct 05, 2022 23:00:00.644 [0x14a94ac1fb38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Scheduling 'Big Sky - E3 - A Brief History of Crime' for assimilation.
Oct 05, 2022 23:00:00.646 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Subscription: Found existing library item 'Big Sky (2020)' (24353)
Oct 05, 2022 23:00:00.649 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] There were 3 top-level paths for Big Sky (2020).
Oct 05, 2022 23:00:00.650 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Assimilator: Postprocessing, we're going to put `Big Sky - E3 - A Brief History of Crime` in `/media/tvshows/.grab/Season 03/Big Sky (2020) - S03E03 - A Brief History of Crime.ts`
Oct 05, 2022 23:00:00.650 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Assimilator: Moving "/media/tvshows/.grab/2d670680b3f82705139140b1ed5d976763643b30-ac6b423a4e3ad886f1d8b9a9ee101ea789b0b178/Big Sky (2020) - S03E03 - A Brief History of Crime.ts" to "/media/tvshows/.grab/Season 03/Big Sky (2020) - S03E03 - A Brief History of Crime.ts"
Oct 05, 2022 23:00:00.652 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Subscription: Found existing library item 'Big Sky (2020)' (24353)
Oct 05, 2022 23:00:00.667 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Added new metadata item (A Brief History of Crime) with ID 24616
Oct 05, 2022 23:00:00.669 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Doing expensive tags write for 'A Brief History of Crime' because something changed.
Oct 05, 2022 23:00:00.670 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Doing expensive tags write for 'A Brief History of Crime' because something changed.
Oct 05, 2022 23:00:00.671 [0x14a9498b0b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] HubCache: Expiring '1/continueWatching/1/hubs/continueWatching/en-usexternal-media,indirect-media/contentDirectoryID=playlists%2C1%2C2&includeDetails=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1' because of event plex.event.item.created.
Oct 05, 2022 23:00:00.671 [0x14a9498b0b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] HubCache: Expiring '1/tv.recentlyadded.2/1/hubs/promoted/en-usexternal-media,indirect-media/contentDirectoryID=2&count=10&excludeContinueWatching=1&includeDetails=1&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1&pinnedContentDirectoryID=playlists%2C1%2C2' because of event plex.event.item.created.
Oct 05, 2022 23:00:00.674 [0x14a94eb28b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Updating metadata item (save) (A Brief History of Crime) with ID 24616
Oct 05, 2022 23:00:00.694 [0x14a948ff7b38] DEBUG - [Grabber/2d670680b3f82705139140b1ed5d976763643b30] Media Analyzer: Performing on-the-fly analysis on 1 item.
I think this is where the issue is but there is no error?
This is the weird line that isn’t an error, but doesn’t look right to me:
Normally I would expect to see it move from a directory under .grab to a location specific to the show in your library. Is this TV Show library defined as using folder /media/tvshows? If so, I would have expected it to move to /media/tvshows/Big Sky (2020)/Season 03/, not /media/tvshows/.grab/Season 03/. It moving the file to, and leaving it under .grab is definitely a problem.
Working from log snippets is tough, so I’m going to ask a lot of questions:
  • Has this worked for you previously and only recently become a problem, or is this a new setup?
  • Would you go into Plex Web, then open “edit” for this library, and check where the folder is defined?
  • Is this a bare metal install, or Docker?
  • What OS is this? It’s obviously some flavor of Linux, but can’t tell which.
I don’t know if this is your problem but if this is Ubuntu (or Mint), then I know that Plex recommends to not use /media as a library location because of how the OS (Nautilus I think) claims ownership of /media. If this is an auto mounted disk then you should likely manually mount it someplace else and/or set it up in fstab so it mounts someplace else on boot.
Not sure if I am having the same problem I have Unbuntu 18 it has been working fine. Think it might be a recent update that has caused it.
Not sure what logs you need to see what is happening.
Also noticed after it disappears it no longer shows it in the DVR schedule for the day.
I had updated to PlexMediaServer-1.29.1.6260-420892357
I removed DVR added it again, waited till guide updated, then started a recording it failed very quickly.
Could also no longer watch a channel on live tv.
Downgraded back to PlexMediaServer-1.28.2.6151-914ddd2b3 deleted and re added dvr seem to work fine again for a recording
I was able to fix the issue I added another folder to my TV Show Library /media/plex-recordings. Then I was able to go into the show recording and select the folder I wanted plex to store the recording in and it works(Moves the show from .grab to /media/plex-recordings &/or moves them to /media/tvshows).
I think it was some kind of weird issue due to being run in a docker container or the fact that I have tried plex DVR on this install in the past and some old settings causing issues from a year or 2 ago.
Also you are correct on the /media folder because of how Nautilus claims ownership. I will be switching this to /data in the future but I want to make a backup of my library files before doing so.
Your issue sounds much different then the issues I had if you could provide your logs I’d be happy to sift through them.
