Plex Agent issues? "Unknow metadata type: folder" and more
Server Version#: 1.40.1.8173
Player Version#: N/A
Hello all,
I’m hoping you guys can help me with my obsure issues I have with please.
For one, it seems that my metadata agents are not being found/corrupted, I get errors like:
“Request for plug-in [tv.plex.agents.movie] but it doesn’t exist.” (Same for series)
also when refreshing metadata for a library I get quite often :
“Unknown metadata type: folder”
along with warnings such as:
" QueryParser: Invalid field ‘contentDirectoryID’ found, ignoring."
“QueryParser: Invalid field ‘smart’ found, ignoring.”
So my issue right now is that for one, I cannot refresh metadata of a library, I only get errors. Also Plex has been crashing unexpectedly, I suspect some corruption somewhere. I have done DB repair, I even restored a backup I had from last month. It passes the Pragma check, and I have also reindexed. I’m afraid it’s possible my issue is also present in my backups.
Are there any obvious signs I’m missing here? What would you recommend I do in case of some corruption?
Please find my verbose/debug logs attached here (removed sensitive info).
zipped.zip (616.5 KB)
I could really use some help to find out what could be causing these issues on my end. I appreciate the help.
Me too, lots of:
Mar 26, 2024 17:48:00.831 [131110980590392] WARN - [Req#2de0] SLOW QUERY: It took 320.000000 ms to retrieve 84 items.
Mar 26, 2024 17:48:00.893 [131111011273528] WARN - [Req#2ddf] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:00.894 [131111011273528] WARN - [Req#2ddf] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:00.900 [131110950042424] ERROR - [Req#2de6] Unknown metadata type: folder
Mar 26, 2024 17:48:00.901 [131110950042424] WARN - [Req#2de6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:01.030 [131110968068920] WARN - [Req#2d2b] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:01.030 [131110968068920] WARN - [Req#2d2b] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:01.102 [131110947285816] WARN - [Req#2c0e] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:01.102 [131110947285816] WARN - [Req#2c0e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:01.463 [131110947285816] WARN - [Req#2c0e] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:01.463 [131110947285816] WARN - [Req#2c0e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:02.082 [131110968068920] WARN - [Req#2d2b] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:02.082 [131110968068920] WARN - [Req#2d2b] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:02.848 [131110950042424] WARN - [Req#2de6] SLOW QUERY: It took 220.000000 ms to retrieve 25 items.
Mar 26, 2024 17:48:02.874 [131110968068920] WARN - [Req#2d2b] SLOW QUERY: It took 340.000000 ms to retrieve 50 items.
Mar 26, 2024 17:48:04.166 [131110962146104] WARN - [Req#2bdb] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:04.166 [131110962146104] WARN - [Req#2bdb] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:05.402 [131110950042424] WARN - [Req#2bd0] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.431 [131110958410552] WARN - [Req#2e85] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.469 [131110972316472] WARN - [Req#2e88] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.499 [131111011273528] WARN - [Req#2e8b] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.522 [131110947285816] WARN - [Req#2e8e] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.556 [131110933941048] WARN - [Req#2e91] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.589 [131110952151864] WARN - [Req#2e94] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:05.630 [131110968068920] WARN - [Req#2e97] QueryParser: Invalid field 'skipRefresh' found, ignoring.
Mar 26, 2024 17:48:08.571 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:08.571 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:11.305 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:11.305 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:48:15.067 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 26, 2024 17:48:15.067 [131110958410552] WARN - [Req#2e2e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 26, 2024 17:49:17.722 [131110947285816] ERROR - [Req#2fb1] Unknown metadata type: folder
Mar 26, 2024 17:49:19.872 [131110884727608] ERROR - [Req#2fbb] Unknown metadata type: folder
Mar 26, 2024 17:49:21.747 [131110947285816] ERROR - [Req#2fc9] Unknown metadata type: folder
Mar 26, 2024 17:49:23.982 [131110884727608] ERROR - [Req#2fd4] Unknown metadata type: folder
and ios app Couldn't retrieve the play queue for this item. Please try again
and it takes me 15 minutes to restart pms each time
