Plex always fails to finish movies overnight
Server Version#: Version 1.32.0.6918 running on UNRAID
Plex Media Server Logs_2023-04-13_08-21-26.zip (4.3 MB)
every night when i set plex to play a movie or a playlist of movies, at some point throughout the night it will stop playing and i will wake up to an error “an error has occurred while attempting to play this video. please check your connection and try again”
I know for a fact the movies work and play in plex no problem but something is happening at night almost every night. I am using an nvidea shield that is hardwired to stream. It was also doing this with a hardwired apple TV so i dont think its the streaming unit.
I also recently have been getting notifications that my database is corrupt but everything is running fine aside from this one issue. I had a database corruption issue once before and i regrettably deleted and rebuilt the database. I would not like to have to do this again since it was a real pain getting all my plays synced back up.
I have attached my logs. I have no idea where to begin to look to figure the issue out.
anyone have any incite?
Thank you so much! Do you have any idea how i would run this on my unraid server? Or could i copy the database on to my PC and run the repair there?
I figured it out and ran the repair. I will report back if this solved my issues. Thank you!
