Plex analysis wrong audio
Plex analysis some of my movies with the wrong audio.
For example I ripped the movie Jumper with makemkv, I selected the english and and german 7.1 DTS-HD track. When uploaded to plex it shows the following audio options: german - DTS 7.1 and english - DTS 3.1. At first I thought it ripped the wrong audio but if check the file with mkvtoolnix info it shows 7.1 surround for both audio tracks.
Media Info(plex):
Media
Video Resolution 1080p
Duration 1:28:27
Bitrate 27457 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Audio Profile ma
Video Profile advanced
Part
Duration 1:28:27
File Jumper (2008).mkv
Size 16.96 GB
Audio Profile ma
Container MKV
Indexes sd
Codec VC1
Bitrate 25921 kbps
Language English
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 1080
Level 3
Profile advanced
Ref Frames 1
Scan Type progressive
Width 1920
Codec DCA
Channels 7.1
Bitrate 768 kbps
Language Deutsch
Audio Channel Layout 7.1
Bit Depth 24
Profile ma
Sampling Rate 48000 Hz
Title Surround 7.1
Codec DCA
Channels 3.1
Bitrate 768 kbps
Language English
Audio Channel Layout FC+LFE+BL+BR
Profile hra
Title Surround 7.1
For another movie with the same problem that I ripped again but this time with a separate core audio I get the same result for the “faulty” track but the core audio gets analysed right as DTS-5.1
Is there a setting that I’m missing or did I rip wrong.
Appreciate the help
Server is running on a nvidia shield with version: 1.13.0.5023
Edit: Nevermind, I now know what is causing the problem it is the DTS HRA profile, apparently plex doesn’t support it. And on the blu ray box of jumper it says 7.1 DTS-HD and HRA or high resolution is missing but in makemkv you see only the HRA track.
So my fault :wink: Should have seen that
