Plex and feralhosting setup problems
Server Version#:1.16.6.1592-b9d49bdb7
ok i have purchased a second server from feral hosting and have followed all of their instructions.
i have numerous issues though and feral just say its a bug/glitch within plex. my over server i use with them works perfect. the problem i have is for some reason the server shows up twice so appears to duplicate. yet only one instance of it shows in authorized devices. i have uninstalled and reinstalled about 6 times so far. also i cannot get a secure connection to the server no green spot like my other box. i also share libraries with some other users and it now shows i am sharing multiple libraries with them even though the server no longer exists as such as it was un installed then readded … so shows a new server. how can i remove the bugged out libraries that do not exist ? also one minute the server shows as being fully accessible outside of the network … give it a hour and it goes off again … so i then reboot it via kitty.
i have searched and searched the forums . but with little access to a feral server. i cant have a remote desktop installed so everything is done via ssh commands.
my port number is below 20000 and if i just change it via the feralhosting.com:32400/web then i just lose server settings.
i am a bit of a novice so any advise would be great.
Get a different hosting provider Failure in ParseHeader: HTTP/1.1 403 Forbidden
