Hello. I have a question. Recently I can not longer start Plex with my Mac mini. It is an old device (mid 2011) and the current OS Version is Sierra 10.12.6. Now Plex only appears with Os Sierra from Version 10.13. be started. Unfortunately Apple no longer offer an update for my old Mac Mini. Do I have to buy a new Mac Mini now or is there an option to install an “old” version of Plkex. I´ve already tried “uptodown.com” but unfortunatly it doesn´t work. Any tips or help here? Thank you in advance.
Thread below has a link to the last Plex version that runs on Sierra.
You might double check supported OS versions for your mini. My early 2011 MacBook Pro runs High Sierra, 10.13.
Just to double-up on what @FordGuy61 said: anything that can run 10.12 can also run 10.13.
Apple did a weird thing, you have to get it in the App Store, not in System Settings.
Click this:
Hello.
Ok, first of all thank you very much for your answers.
I first tried the Plex link and it worked.
Then I tried updating Sierra as suggested and that worked fine too.
So, I got everything up and running again and I am infinitely grateful to you. Great support. Thank you.
