Plex and Sonos - únable to play etc etc
Did Plex ever fix the Plex-Sonos service ?
I have been through just about every discussion on the problems on this forum,
(specifically not playing tracks with connection to plex lost error)
There seems no answer, perhaps it never got out of BETA
perhaps it just fails on some networks, perhaps it never worked.
Everything is up to date on my network, latest versions of everything.
Plex is on a QNAP which may be an issue, but nothing I can track down.
Anyone else running PLEX-Sonos seamlessly ??
Any PLEX or Sonos gurus out there ?
It does work fine for me, but only if I use an AirPort Extreme, if I switch to my isp supplied router it just doesn’t work. I assume it’s something to do with loop back.
The difference between the airport and the isp router is obvious as when you use the sonos app it can’t play any plex tracks. However everything else works like remote access etc with either router. Didn’t matter if it was manual port forward or upnp sonos never worked on the isp router.
Whether or not that’s the problem you have I don’t know.
