Plex and tidal
Server Version#:1.19.1.2621
Player Version#:7.30
HI, i purchased a tidal subscription and installed the bin file on my pr2100, but i don’t see it in my plex. how do i enable it?
Here you go.
Considering you already got your Tidal subscription, you might want to look at the " Link to an Existing TIDAL Subscription for Access" section…
There’s also a place to enable/disable Tidal in the Settings area. For some odd reason, the Tidal item was recently renamed to “Music”:
got it working thank you very much.
tidal would be great if plex had a music player. with no widget, i have to open the plex app every time and i pretty much only listen to music while i’m driving so i don’t need that distraction. also, without a stand alone app, i don’t see the options like gain.
https://plexamp.com – very lightweight
thank you for the reply but unfortunately i was hoping for an android widget. at home, i just play it through my smart tv.
