Hello
Sorry but build not allow turn on notification
Bug not resolve for me too
Hello
Thanks for trying that build, oddly that disables the media notification so it should of solved the issue. Will have a dig to see if we have another media notification somewhere.
Iāll give it a hoon and report back soon
Can confirm that disabling the media notification fixed it for me, too.
Beta build has fixed for me, at least so far. All notifications are on, and playback has worked consistently for last hour or so. Good work @sixones !
All the fixes I have tried, have only been temporary and then it stops working again.
Itās now been 6 days since I disabled the media notification and Iāve had zero issues with videos stalling.
Still no news ? Itās been more than a month without beeing able to use my Plex Pass at all
Disabling PiP has stopped working as a work around. Plex on Android 12 needs fixing. This is crazy.
try disabling notifications also
thank you, that worked. I hope this is a bit more permanent. Regardless, thank you again.
Using the beta build and I had to disable Plex notifications for it to work.
When notification was enabled, videos rarely worked. I only had a video that was playable twice after so many attempts. A pause would break playback.
After the latest Android update yesterday the payback and crash issues are gone.
Build Number : G996BXXS3BULC
Android version : S(Android 12)
Release Date : 2021-12-27
Security patch level : 2021-12-01
So thereās a new Samsung update on its way, gives me hope !
Issue still exists after enabling media notifications with the latest update as described above.
Then disabled media notifications and now works like before⦠So playback bug still present.
Also running S21 Ultra with Android 12 OneUI 4. Was unable to play any video.
Installed the Plex for Android 8.28.0.29997-beta
Then went into the āapp infoā for plex via android settings and disabled notifications. This allowed video to play again. (After a force close of the app).
I have not allowed any permissions for Plex. Phone, Storage or Microphone.
If I go back anf enable notifications, this stops the playback from working.
My phone must be cursed : I have updated to G996BXXS3BULC, removed media notifications in Plex, kill the process, restart the phone, burn 2 or 3 witches, but still āSomething went wrongā when I try to play something on my TV.
Iām sorry to say that I give it another month, and Iāll quit paying Plex Pass. Itās not a threat or anything near that, just the fact that I wonāt be paying anymore for a service I cannot use.
If the issue isnāt happening when youāre just playing on your phone, then youāre clearing running in to a different issue from this.
Try a different TV, or a different phone on your current TV. Or maybe contact support regarding your issue as it may not be the same as the issue presented here.
Iām 99% sure itās the right problem, as it began to occur from the exact day I had the first S21 update.
Chuck me a log dump and iāll take a look, though iām no expert. If you havenāt checked these logs yourself, iād suggest starting there.
