Plex Android Library Menu not working
Server Version#: 4.147.1
Player Version#: 2026.2.0
After the newest update when I click on libraries the menu pulls up but not far enough to see all my libraries and I can’t scroll or enlarge it. I have not had this issue before. I’m running the latest Android 16 on a pixel 10 pro XL and latest plex app and server update.
Did you somehow force the app to run in landscape? It’s designed to be in portrait.
Negative that’s portrait mode just cropped. I have 3 libraries and can only see the one really well I can barley see the top of the other but there’s no way to scroll or move it around. Someone else on Reddit says they have 17 libraries and are in the same boat as me.
Ok. I can see upto 8 libraries fine. 9 gets cut off. I’ll need to create more libraries to test 10+. Something else also looks wrong in your image. The server name is indented, mine is aligned with the library name.
I censored my library name because it has my real name in it
Thank you for reporting. We are aware of this issue.
