I am trying to get auto quality working for my apps including Android. I can only get the serve to direct play if the “Play Smaller Videos at Original Quality” option is checked. If it’s not checked the app will crash. Any help to get this feature working will be great thanks.
unfortunately the only app I have that is officially supported is android. My PHT is on a linux machine that is not official as far as I know. I can get the files to Direct Play but I other then that I have issues. The Server is on a dedicated desktop so it has plenty of power.
The android app log seems to be too large to paste directly I’ll cut it short and paste it. I cannot seem to get any transcoding working whatsoever either through my HT on another network or through android. Over the wan that is locally it works and direct play works over the wan as well. Just transcoding in any capacity.
Ok, that sounds like an issue with your server, so I will need the PMS logs to look into the transcoder issue. I’ll still need the Android app logs to look into that crash.
