Hi community,
The folders stored in TV Shows are not seen by Plex, is this a configuration problem?
The naming is correct though.
The .mkv files, etc. that are at the root of TV Shows are directly seen by Plex, but not if they are in a folder.
You can see this screenshot from my folder.
Thank you community !
Could you help me ?
You’re using too many . characters. That’s all. You can’t replace spaces and use it as the name-episode-title delimiter concurrently.
Idea and recommended format:
The Handmaids Tale/
Season 02/
The Handmaids Tale.S02E13.ext
additional nesting within the season is not helpful.
FileBot / TheRenamer will make easy resolution of this
Yes. That is not the proper structure. It should be
Main folder
- Name of TV Show
– Season XX (this is not required but highly recommended)
— Name of TV Show - SxxEyy.mkv
- Name of next show
etc…
You’ve got episodes from multiple shows jumbled up with folders.
system
Closed
4
