Hi im also having issues with remote access, any chance you can reset my cert plz?
[mod edit: Done. Please stop and restart your Plex server.]
Edit - Thank you!!!
Edit - Thank you!!!
Hey, I think Iām seeing the same thing. Expired cert and 429s when it tries to renew, Iāve left the server stopped for a couple hours as well.
[mode edit: yes, you were affected. Please stop and restart your server.]
It seems like I have a similar issue, error acquiring cert, failed to upload CSR, and 429s. I turned the server off overnight and the issue persisted this morning.
[mod edit: Please stop and restart your server.]
Same here unfortunately. CERT: Error acquiring new certificate: Failed to upload CSR: 429. Thanks in advance for your help!
Edit: Thanks for your help, that got it!
Same issue. No server changes. Version 1.43.2.10687.
Seems like Iāve also been hit with the expired certificate. Getting CSR :429 in PMS logs. If a mod could also fix it for me, my parents would love you very much ![]()
Much appreciated
Looks like my cert is also stuck\hung after troubleshooting a GPU passthrough on my lxc container, could I get mine reset please?
May 17, 2026 05:39:11.650 [124808105405240] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429,
[mod edit: Youāve had 5 new certs delivered to you in short succession. Now you are rate-limited. Shut down your server for at least 12 hours, then start it back up. Donāt clear out the whole /Cache folder within your plex data folder when experimenting.]
Iām also hitting this issue as of yesterday. Iāve tried logging out/reclaiming my server, and restarting, and the plex direct cert is still expired. Can I get some mod help?
[mod edit: Done. Wait a bit, then stop and restart your server.]
I believe Iām also experiencing this issue after restarting - can I also get some assitance?
I am hitting this same issue as far as I can tell. Can you reset my certification? Thanks so much!
Exact the same thing happened to me, could you please help me with my certificate?
Thank you very much!
Hi, I think this has recently started to happen for me as well. Can you reset mine as well? Thanks.
Hello, would you mind reseting my certificate as well? Thank you!
Seeing error 429, I believe I am having the same issue as above.
Iāve spent a few days trying to solve this but if it is an expired cert that would be great for some mod help. Tried a server backup/reinstall/restore but the same behavior. Much appreciated to whomever can kick my cert a refresh.
[mod edit: Please stop and restart your server now.]
Hello, I started seeing the same issue on my server as well recently. It started happening a couple of days ago. Could I please have my certificate reset as well?
Also this seems to be a widespread issue, any plans on a fix?
[mod edit: your serverās certificate is perfectly valid.]
Apologies. I seem to have gotten a fail to get certificate in my logs, but the actual issue was port forwarding no longer working out of the blue. All ok now.
Can I please get a reset on my serverās certificate? Already tried shutting down the server for 30 minutes, still getting 429s.
It sounds like thereās a new cert that got issued previously but the server never received the new cert or something (Plex API call got interrupted?), so Letās Encrypt is unable to re-issue the cert.
can i get a reset too?,
im getting āMay 26, 2026 20:08:59.953 [16484] ERROR - CERT: Error acquiring new certificate: Failed to upload CSR: 429ā
been disconnected for days. thanks
