In DSM6 in order to successfully install a Plex install package on the command line you first had to add the Plex key to package manager.
On DSM7 there does not appear to be a way to add a third party key. Will I be able to install the Plex package through the command line without getting an error?
This is needed for an auto update script I am running under DSM6.
What would the correct command be to use under DSM7?
I have a spare Synology DS920 I have cloned from my main system (made it exactly the same down to every setting) and upgraded it to DSM7 and am now using it to play around with including PLEX and all of the scripts I use.
As such I would be happy to help test the updates to the script you wrote and supplied to the author as it is a 100% test bed system only.
