Hi. Just downloaded the Plex app on Android but can’t see any four digit code, can someone tell me where I might find this.
Many thanks ![]()
Many thanks ![]()
If this is the Plex app on a mobile, there won’t be a 4-character code to link it to your account. Instead you should see an option to sign into the app using your Plex account.
The option to link apps to your account using the link code is used by apps that don’t usually have their own keyboard (e.g. smart TVs, incl. Android TV).
