Plex Commercial Skipper Not working on MPEG2 TS or H264 MP4 - Error Unsupported Video Codec - Raspberry Pi 4
Server Version#: 1.25.2.5319
Player Version#: Plex Web
Tuner Make/Model: HDHomne
Guide/Lineup name: Guide
Using XMLTV?: OTA
Channel number/Name: All
OS Server: Raspberry Pi Buster 32 bit
Hardware: Pi4 4GB
Lifetime Plex Pass
Hi everyone, I wonder if anyone can help me.
I am unable to get the commercial skipping to work. I wonder if i am the only one? The error i get is:
Unsupported codec!
Could not open video codec
Normally I write my .ts files to an SMB share but for speed I copied one locally to produce the below as I had seen somewhere that SMB could be the issue (it isn’t I don’t think).
Somethings to consider -
  1. I did this on a fresh install of the OS, with just plex installed from the website.
  2. The Raspberry Pi 4 does not support hardware mpeg2 decoding, you can’t get a license it just says use software and it will be fine - and its true I can playback mpeg2 stuff fine in plex using android or the web service with transcoding all running fine — HOWEVER I wonder if this is why Comskip/Plex Commercial Skipper/FFMPEG is throwing a wobbly because its trying to use mpeg2_mmal ??? - Just a guess.
  3. It also doesn’t work on a h264 mp4 file either (same file but transcoded with ffmpeg before hand to aac & h264)… So maybe tha blows the mpeg2_mmal idea out the window?
Any thoughts, help or suggestions, would be greatly appreciated.
Log/Terminal output below.
Running Plex Commercial Skipper
    sudo ./Plex\ Commercial\ Skipper /home/pi/Downloads/output.ts --ini="/var/lib/plexmedias  erver/Library/Application Support/Plex Media Server/DVR/comskip.ini"
    Plex Commercial Skipper, made using ffmpeg
    Donator build
    The commandline used was:
            "./Plex Commercial Skipper"
            "--ini=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/DVR/comskip.ini"
    Setting ini file to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/DVR/comskip.ini as per commandline
    Using /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/DVR/comskip.ini for initiation values.
    Mpeg:   /home/pi/Downloads/output.ts
    Exe     comskip.exe
    Logo:   /home/pi/Downloads/output.logo.txt
    Ini:    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/DVR/comskip.ini
    Detection Methods to be used:
            1) Black Frame
            2) Logo - Give up after 2000 seconds
            3) Resolution Change
            4) Aspect Ratio
    ComSkip throttles back from -0001 to -0001.
    The time is now 1700 so it's full speed ahead!
    Settings
    [Main Settings]
    ;the sum of the values for which kind of frames comskip will consider as possible cutpoints: 1=uniform (black or any other co  lor) frame, 2=logo, 4=scene change, 8=resolution change, 16=closed captions, 32=aspect ration, 64=silence, 255=all.
    detect_method=43
    ;Set to 10 to show a lot of extra info, level 5 is also OK, set to 0 to disable
    verbose=10
    ;Frame not black if any of the pixels of the frame has a brightness greater than this (scale 0 to 255)
    max_brightness=60
    maxbright=1
    ;Frame not pure black if a small number of the pixels of the frame has a brightness greater than this. To decide if the frame   is truly black, comskip will also check average brightness (scale 0 to 255)
    test_brightness=40
    max_avg_brightness=25
    max_commercialbreak=600
    min_commercialbreak=25
    max_commercial_size=125
    min_commercial_size=4
    min_show_segment_length=250
    max_volume=500
    max_silence=100
    non_uniformity=500
    [Detailed Settings]
    min_silence=12
    remove_silent_segments=0
    noise_level=5
    brightness_jump=200
    fps=22
    validate_silence=1
    validate_uniform=1
    validate_scenechange=1
    global_threshold=1.05
    disable_heuristics=4
    cut_on_ac_change=1
    [CPU Load Reduction]
    thread_count=2
    hardware_decode=0
    play_nice_start=-1
    play_nice_end=-1
    play_nice_sleep=2
    [Input Correction]
    max_repair_size=200
    ms_audio_delay=5
    volume_slip=40
    lowres=0
    skip_b_frames=0
    [Aspect Ratio]
    ar_delta=0.08
    cut_on_ar_change=1
    [Global Removes]
    padding=0
    remove_before=0
    remove_after=0
    added_recording=14
    delete_show_after_last_commercial=0
    delete_show_before_first_commercial=0
    delete_show_before_or_after_current=0
    delete_block_after_commercial=0
    min_commercial_break_at_start_or_end=39
    always_keep_first_seconds=0
    always_keep_last_seconds=0
    [USA Specific]
    intelligent_brightness=0
    black_percentile=0.0076
    uniform_percentile=0.003
    score_percentile=0.71
    [Main Scoring]
    length_strict_modifier=3
    length_nonstrict_modifier=1.5
    combined_length_strict_modifier=2
    combined_length_nonstrict_modifier=1.25
    ar_wrong_modifier=2
    ac_wrong_modifier=1
    excessive_length_modifier=0.01
    dark_block_modifier=0.3
    min_schange_modifier=0.5
    max_schange_modifier=2
    logo_present_modifier=0.01
    punish_no_logo=1
    [Detailed Scoring]
    punish=0
    reward=0
    punish_threshold=1.3
    punish_modifier=2
    reward_modifier=0.5
    [Logo Finding]
    border=10
    give_up_logo_search=2000
    delay_logo_search=0
    logo_max_percentage_of_screen=0.12
    ticker_tape=0
    ticker_tape_percentage=0
    ignore_side=0
    ignore_left_side=0
    ignore_right_side=0
    subtitles=0
    logo_at_bottom=0
    logo_threshold=0.75
    logo_percentage_threshold=0.25
    logo_filter=0
    aggressive_logo_rejection=0
    edge_level_threshold=5
    edge_radius=2
    edge_weight=10
    edge_step=1
    num_logo_buffers=50
    use_existing_logo_file=1
    two_pass_logo=1
    [Logo Interpretation]
    connect_blocks_with_logo=1
    logo_percentile=0.92
    logo_fraction=0.4
    shrink_logo=5
    shrink_logo_tail=0
    before_logo=0
    after_logo=0
    where_logo=0
    min_black_frames_for_break=1
    [Closed Captioning]
    ccCheck=0
    cc_commercial_type_modifier=4
    cc_wrong_type_modifier=2
    cc_correct_type_modifier=0.75
    [Live TV]
    live_tv=0
    live_tv_retries=4
    require_div5=0
    div5_tolerance=-1
    incommercial_frames=1000
    [Output Control]
    output_default=1
    output_chapters=0
    output_plist_cutlist=0
    output_zoomplayer_cutlist=0
    output_zoomplayer_chapter=0
    output_scf=0
    output_vcf=0
    output_vdr=0
    output_projectx=0
    output_avisynth=0
    output_videoredo=0
    output_videoredo3=0
    videoredo_offset=2
    output_btv=0
    output_edl=1
    output_live=0
    edl_offset=0
    timeline_repair=1
    edl_skip_field=0
    output_edlp=0
    output_bsplayer=0
    output_edlx=0
    output_cuttermaran=0
    output_mpeg2schnitt=0
    output_womble=0
    output_mls=0
    output_mpgtx=0
    output_dvrmstb=0
    output_dvrcut=0
    output_ipodchap=0
    output_framearray=0
    output_debugwindow=0
    output_tuning=0
    output_training=0
    output_false=0
    output_aspect=0
    output_demux=0
    output_data=0
    output_srt=0
    output_smi=0
    output_timing=0
    output_incommercial=0
    output_ffmeta=0
    output_ffsplit=0
    delete_logo_file=0
    output_mkvtoolnix=0
    cutscene_frame=0
    cutscene_threshold=10
    windowtitle=""Comskip - %s""
    cuttermaran_options=""cut=\""true\"" unattended=\""true\"" muxResult=\""false\"" snapToCutPoints=\""true\"" closeApp=\""true\""""
    mpeg2schnitt_options=""mpeg2schnitt.exe /S /E /R25  /Z %2 %1""
    avisynth_options=""LoadPlugin(\""MPEG2Dec3.dll\"") \nMPEG2Source(\""%s\"")\n""
    dvrcut_options=""dvrcut \""%s.dvr-ms\"" \""%s_clean.dvr-ms\"" ""
    [Sage Workarounds]
    sage_framenumber_bug=0
    sage_minute_bug=0
    enable_mencoder_pts=0
    [mpegts @ 0xb5521800] start time for stream 2 is not set in estimate_timings_from_pts
    [mpegts @ 0xb5521800] start time for stream 4 is not set in estimate_timings_from_pts
    [mpegts @ 0xb5521800] PES packet size mismatch
    [mpegts @ 0xb5521800] Packet corrupt (stream = 1, dts = 2567819568).
    [mpegts @ 0xb5521800] stream 2 : no TS found at start of file, duration not set
    [mpegts @ 0xb5521800] Could not find codec parameters for stream 2 (Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels): unspecif  ied frame size
    Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
    Input #0, mpegts, from '/home/pi/Downloads/output.ts':
      Duration: 01:01:37.54, start: 24834.272533, bitrate: 2127 kb/s
      Program 1
        Metadata:
          service_name    : Dave
          service_provider:
        Stream #0:0[0x191]: Video: mpeg2video ([2][0][0][0] / 0x0002), none(top first), 544x576 [SAR 32:17 DAR 16:9], 25 fps, 25   tbr, 90k tbn, 50 tbc
        Stream #0:1[0x192](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, 128 kb/s
        Stream #0:2[0x194](eng): Audio: mp3 ([3][0][0][0] / 0x0003), 0 channels (visual impaired) (descriptions) (dependent)
        Stream #0:3[0x193](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
      No Program
        Stream #0:4[0x12]: Data: epg
    Unsupported codec!
    Could not open video codec**
    /home/pi/Downloads/output.ts: could not open video codec
Echo of Variables Set - because I saw somewhere that might help - it didn’t help me at least?
    pi@plex:/lib/plexmediaserver $ echo $EAE_ROOT
    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-1625-linux-armv7neon/
    pi@plex:/lib/plexmediaserver $ echo $FFMPEG_EXTERNAL_LIBS
    /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/fb9eae3-4185-linux-armv7neon/
FFMPEG2 Codecs Grep for mpeg2 - Its the most up to date via apt… =/
 pi@plex:/lib/plexmediaserver $ ffmpeg -hide_banner -codecs | grep mpeg2                                                   DEV.L. mpeg2video           MPEG-2 video (decoders: mpeg2video mpegvideo mpeg2_mmal mpeg2_v4l2m2m ) (encoders: mpeg2video mpeg2_vaapi )
Running Plex Commercial Skipper on the *.mp4 file (removed the ini file output becaues its just a repeat of above for the *.ts)
            /home/pi/Downloads/output.mp4
    Mpeg:   /home/pi/Downloads/output.mp4
    Exe     comskip.exe
            1) Black Frame
            4) Aspect Ratio
    The time is now 2033 so it's full speed ahead!
    Settings
    SETTINGS START
    CONTENT HERE REMOVED AS ITS THE SAME AS FOR THE *.TS
    SETTINGS END
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/pi/Downloads/output.mp4':
      Metadata:
        major_brand     : isom
        minor_version   : 512
        compatible_brands: isomiso2avc1mp41
        encoder         : Lavf58.76.100
      Duration: 01:01:37.52, start: 0.000000, bitrate: 1361 kb/s
        Stream #0:0(und): Video: h264 (avc1 / 0x31637661), none, 544x576, 1228 kb/s, SAR 32:17 DAR 16:9, 25 fps, 25 tbr, 12800 tbn, 12800 tbc (default)
        Metadata:
          handler_name    : VideoHandler
          vendor_id       : [0][0][0][0]
        Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, 2 channels, 126 kb/s (default)
        Metadata:
          handler_name    : SoundHandler
What user are you running Plex as?
Basically the tv directory needs read/write/execute permission.
So typically /mnt/mydvr/ folder is owned by plex:plex; and its all 755.
But to run the above i am running it as pi sudo, and they are not part of the plex group - maybe add them?
